coolant leak water pump replaced
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By amunderdog
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, coolant leak water pump replaced in Past Cadillac Vehicle Discussion; Okay before today I let my 03 DTS sit fpr weekend because u could fill it with coolant and 2 ...
    DSNCB919 is offline Cadillac Owners Enthusiast
    Automobile(s): 1990 Cadillac Seville 2003 Cadillac DTS 2010 DTS Platinum
    Jun 2009
    North Carolina
    28
    538
    Okay before today I let my 03 DTS sit fpr weekend because u could fill it with coolant and 2 blocks down road say check coolant... anyways today I took it to the local cadillac dealeer they said leak was due to failing water pump.. so I pay $542.83 for coolant ,pump kit, gasket , thermostat, and seal.. took about 4.5 hours. . On highway ride back home 20 min in again check coolant. I get home looks fine. I come back out 2 hr later its EMPTY.. im pissed not what I consider cheap repair. . What could be causing leak? And how should I approach dealer I feel robbed right now
    68
    81,926
    Re: coolant leak water pump replaced
    4.5 hrs? WOW! I suspect most of that was just waiting your turn.
    Don't panic. It is not uncommon for it to take several trips to purge all the air out of the system. Granted, for $542 it should have been done at the dealer. Just top it off to the 1/2 way point and check it again after the next drive or two and you should be just fine.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,370
    Quote Originally Posted by DSNCB919 View Post
    you didn't only get ROBBED -
    you were ROYALLY SCREWED -
    too bad you didn't ask us FIRST -
    we could have saved you AT LEAST $250 -
    you could buy a genuine ACDelco water pump - $70.25 -
    http://www.partsgeek.com/catalog/200...ater_pump.html
    or a brand new BOSCH - a very high quality replacement unit -
    for $31.25 - if you wanted to save another $40 -
    plus another $15 for coolant -
    and $10 - for a thermostat - THAT YOU DIDN'T NEED -
    an independent would have charged about $150 for labor -
    TOTAL should have been around - $240 - $250
    but - obviously - the water pump WASN'T the problem -
    if it IS still leaking -
    lots of things -
    which is why you need to PRESSURE TEST the cooling system -
    this will pin-point EXACTLY where real leak is -
    that is a real tough question -
    you COULD just take the car back -
    explain that after the $550 repair - it still leaks -
    what I would do is take it to an independent shop -
    have THEM do a PRESSURE TEST -
    and DIAGNOSE where the leak actually is -
    THEN - with this knowledge -
    go back to the dealer - explain there is still a leak -
    ask them to do the PRESSURE TEST -
    and REPORT their findings to you -
    depending on what the dealer discovers -
    compared to the independent shop -
    would determine MY course of action -
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    And they did not even check there work?
    Good grief.
    Did you get there complementary reach around or a kiss? maybe both?
    basscatt likes this.
    Jun 2009
    North Carolina
    28
    538
    All I got was free hot chocolate n direct tv
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    +1 You had air in the system. Fill it up to 1/2 way again. These cars are very hard to fill from empty.
    Jun 2009
    North Carolina
    28
    538
    The cadillac dealer I went to while in college was way better. Very honest would take u inside the shop n show you the work needed if it was $$.. now that I graduate have "a good job" and moved back home I feel like the dealer here is fancier but knows ppl make $$ n automatically charge high..... they didnt even return my call
    Jun 2009
    North Carolina
    28
    538
    Nvm they called back and said exactly what ranger said and are checking it now.. Ranger should be paid by these forums
    68
    81,926
    I agree.
  12. Remove Advertisements
