Change back speaker
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Change back speaker in Past Cadillac Vehicle Discussion; Hey everyone I'm James and I have a 03 cadillac deville. My rear speaker had without, I replaced it with ...
    firstlac27's Avatar
    firstlac27 is offline Cadillac Owners Member
    Jul 2013
    3
    Change back speaker
    Hey everyone I'm James and I have a 03 cadillac deville. My rear speaker had without, I replaced it with aftermarket 10 inch speaker which is 600 watts, It works in everything but not as loud as it should be, I just took out old speaker in connected the positive and negative to the new speaker. Can anyone give me a clue on how to make it louder, Its my first Cadillac so please help me. Thank you so much
    vincentm's Avatar
    vincentm is offline Cadillac Owners Connoisseur
    Automobile(s): 1997 Cadillac Eldorado ETC
    Aug 2010
    Kennewick WA
    38
    4,872
    Re: Change back speaker
    Do you have the Bose system? If so that's the problem right there, the original is rated at 2ohms, most aftermarket are 4ohms and up.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by firstlac27
    The new speaker probably had too low sensitivity. There really isn't any way to make it "louder", unless you change the factory subwoofer amp.
    firstlac27's Avatar
    Jul 2013
    3
    If I take the factory amp out wouldn't it mess up the sound from all the speakers, How do I go about that, And don't the whole audio system go through that amp. Thanks for the help
    Not sure if its a Bose system but the old speaker say 2 ohms in back of it. I just got the car maybe a week ago
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    If you went with a higher impedance sub, you'd have to use a separate sub amp, not remove the original.
    DBA-One's Avatar
    DBA-One is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 DeVille
    Nov 2005
    Palm Harbor, FL
    44
    1,043
    I bought an Alpine "bass line" subwoofer to replace the factory unit only because I got it for a great price due to it being an open box item. I didn't want to get in to a sub box, amp and all that. Do you think I'm taking the right approach? I'm not looking for very deep bass, I just want it to fit my moderate needs for sound. Can the factory amp pull that off?
    Sep 2010
    East Boston MA.
    29
    26,325
    With the bass all the way up, the factory sub, along with the mid bass drivers in the front doors, do an OK job of providing a decent amount of bass for most types of music.
    For some of what I listen to, it's not quite enough at lower volume levels, but the main problem for me is that it doesn't play low enough.
    An entry level 8"/10" sub, in a small, sealed box, powered by a small amp, will blow away one of these factory subs in SPL (volume), but not necessarily in sound quality.
    It sounds like you might be better off with the factory sub, rather than putting money into a good SQ sub. However, see if you can find a used JL 10W3 or 12W3 with a box and amp for $200/$300. AWESOME SQ sub, louder than stock, but not too pricy, and doesn't require a ton of power.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,365
    here is a brand new OEM speaker - for $75.65 - with shipping -
    http://www.amazon.com/dp/B000K00DJ8
  11. Remove Advertisements
