2000 DTS rear coil spring replacement
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 DTS rear coil spring replacement in Past Cadillac Vehicle Discussion; Hello, I will be replacing my rear coil springs this weekend and was looking for some tips, warnings...im aware it ...
    09defone is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Deville DTS
    Jul 2013
    Milwaukee, WI
    26
    8
    Smile2000 DTS rear coil spring replacement
    Hello,
    I will be replacing my rear coil springs this weekend and was looking for some tips, warnings...im aware it can be dangerous when dealing with springs, also will be doin my front struts, but the conversion ones, any tips on brands and intallation? Thanks in advance BTW i own a 2000 cadillac deville dts
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    Re: 2000 DTS rear coil spring replacement
    Are you keeping the active suspension or downgrading to the base Deville passive suspension ? Different repair methods for each type - both mechanically and electrically - your entire suspension system is currently monitored for correct operation, height, and electronic control.
    DTS = Deville Touring Sedan. To the best of my knowledge Cadillac is the only division of GM that made the Deville Touring Sedan until 2006 - the later "DTS" is not a Deville - the acronym means nothing.
    Jul 2013
    Milwaukee, WI
    26
    8
    i guess downgrading to passive suspension, i just recently replaced my shocks with monroe conversion kit
    Feb 2006
    57,174
    Several threads on this in the first 3 or 4 pages of this forum - recent - and down in Discussions, Item Specific - Cadilac Tech Tips.
    Try this: Google "cadillac forums 2000 dts strut replacement" or any other question beginning with "cadillac forums 2000 dts .......... "
    While you're researching, always read all the sticky posts at the top of each forum - that's information that is important and timeless. Also, study the entire Cadillac Technical Archive way up ^^^ in the top black bar. There is important info on your car that you need to know.
    Jul 2013
    Milwaukee, WI
    26
    8
    You been very helpful, Thanks
    Much Respect
    Feb 2006
    57,174
    Not a problem. If you ever lose the thread train of thought, go back and skim the previous posts - some advisors will edit their posts (within 24 hours) to add necessary maintenance info.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,869
    Quote Originally Posted by 09defone View Post
    WHY?
    how many miles on the car?
    are they broken? -
    who said you need new springs?
    what brand springs are you planning on using?
    I HOPE you used the MA822 shocks -
    and NOT the 90007 "coil-over" shocks -
    for the front struts -
    the Monroe 90014 kit is the one for you -
    it includes everything you need -
    except new springs and the resistors -
    rockauto.com has the best price - $219 plus $10 shipping - for the entire kit -
    Jul 2013
    Milwaukee, WI
    26
    8
    the car has about 124k and yeah i did put the 9007 why? what did i get myself into?
    what do you think about the monroe struts that come already assembled with the spring
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    They're designed for base Devilles and DHSs (softer springs). Not advisable to mix and match.
    The coil over setup hives a harsher ride, will sag under heavier loads, and several members have had problems with them becoming noisy.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,869
    coil-over shocks just plain SUCK -
    compared to the original air bladder type shocks -
    without a load in the back seat or trunk -
    the rear will ride too high - and the ride will be harsh -
    compared to a real Cadillac ride -
    with a load in the back seat and trunk -
    the rear will ride too low - and handling will suck -
    I can't imagine who talked you into the coil-over shocks - or why -
    but there were/are MUCH better options - that WOULD have saved you money -
    even if the compressor - or ride-height sensor - were not working -
    the MA822 - along with the AK29 - manual fill kit -
    would have been the CORRECT choice -
    MA822 - $58.25 - with free shipping -
    http://www.partsgeek.com/32syvb4-bui...ber.html?fp=pp
    AK29 - $12.75 - also from partsgeek -
    there are two available -
    the 171685 - $115.79 each - plus shipping =
    $255 for the pair - delivered -
    from rockauto.com -
    OR the cheaper 181685 - $66.79 each - plus shipping =
    $152 for the pair - delivered -
    the 171685 are a better quality strut -
    the only "problem" with BOTH - 171685 and 181685 units -
    are that the new springs are the "standard" base Deville and DHS - FE1 "soft" springs -
    compared to the FE3 "firm" springs that came on the DTS -
    this may or may not be a big deal to you -
    personally - I MUCH prefer the soft Cadillac ride -
    the only place you can get a new set of FE3 springs is from the dealer -
    here is the bottom line -
    if was MY car -
    I would go for the 171685 front struts -
    get rid of the coil-over 90007 rear shocks -
    and replace them with the Monroe MA822 -
    and the AK29 manual fill kit if your compressor isn't working -
    you never did say WHY you were going to replace the rear springs -
    but if they DO need replacing - I would recommend -
    MOOG 81011 - $54.79 - for the PAIR - $67 with shipping -
  13. Remove Advertisements
