Sunroof problems on a 2000 DTS
Results 1 to 3 of 3
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Sunroof problems on a 2000 DTS in Past Cadillac Vehicle Discussion; Hello, My sunroof no longer works...it seemed to be jammed, maybe went off track, when it broke the sunroof would ...
    09defone is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac Deville DTS
    Jul 2013
    Milwaukee, WI
    26
    8
    UnhappySunroof problems on a 2000 DTS
    Hello,
    My sunroof no longer works...it seemed to be jammed, maybe went off track, when it broke the sunroof would make a clicking sound and only one half of sunroof would rise...eventually the controls i think went out...its also causing leaks
    Anyone have a similar issue? can i fix it myself? How much for a repair?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,568
    Re: Sunroof problems on a 2000 DTS
    The glass is secured by 4 Torx screws, 2 in each side rail, accessible with the headliner slide open. If those screws loosen the glass gets out of alignment and the mechanism hangs up. The alignment is a normal twice a year maintenance check.
    Proper alignment is with the front edge of the glass/seal exactly flush with the roofline; the rear edge flush to 0.5mm high.
    If alignment won't get things right, you're in the headliner removal/mechanism removal business.
    www.alldatadiy.com is your friend. Subscribe your car.
    Jul 2013
    Milwaukee, WI
    26
    8
    THANK YOUUU...i appreciate it alot
