rear suspension leveling
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Ranger
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, rear suspension leveling in Past Cadillac Vehicle Discussion; hey guys, I tried to post this over the weekend without any success. read several threads but no info I ...
    blalockchiro's Avatar
    blalockchiro is offline Cadillac Owners Fanatic
    Automobile(s): 1997 Deville, 89 Camaro, 07 Silverado
    May 2011
    macon, ga
    363
    hey guys, I tried to post this over the weekend without any success. read several threads but no info I need. question:
    1. I put the Monroe 40046 rear shocks on the caddy on Friday, I am using a manual fill kit for now, until I can get a new compressor. Where do I "level" the car out, do I actually us a construction level and put on the car, to say, or something else?
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: rear suspension leveling
    It should look like this when you get done.
    Looks like pretty much level rockers
    May 2011
    macon, ga
    363
    ok cool....but I did not know if I leveled the car on the truck or where
    or how many inches should the rear be off the ground
    Slipgate is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Deville
    Jul 2009
    48
    710
    I think the rocker panels should be level to the ground. If the ground is level and the rockers are level, you should be very close.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,934
    The proper ride height setting is done with careful measurements at specified suspension arm points. It's tedious service manual work.
    Rear height - as in level control - is initially set at the factory when the level (height) sensors are installed and calibrated. You can set that height anywhere you want - a bit low in the rear, level, or even a bit high. Within sane limits rear ride height will not affect suspension control. Many of these cars look best with just a tad of front rake set in.
    Try to Google several car specification sites - sales dealers - pictures - of your car when new. For just you and maybe a front seat passenger that setting should be just fine. Extra weight in the trunk or back seat and you start all over.
    68
    81,938
    It's not all that critical. Just level it til it looks right.
    basscatt likes this.
    May 2011
    macon, ga
    363
    well, i finally got the new airline kit in yesterday, put on the caddy today and what a difference...i wish i would have taken pics...as soon as we hooked the air hose to the lines, it bumped up the rear, then we put the minimum of 25 pounds of air and the car looked like someone had kicked it in the rear and it stayed up....we laughed, but we lowered the air down to 10 pounds and that leveled the car out. Rides like there is nothing on the road, felt no bumps, curves or anything...awesome ride
    rodnok01's Avatar
    Feb 2012
    NC
    6,635
    Some don't relize the air bladders are actually part of the spring/shock rates. Mine wallowed going down the road and felt horrible until I fixed the level sensor, even braking was affected. All that weight getting a running start forward.
  11. Remove Advertisements
