Can anyone offer advice on ISC ticking issues w/my 1990 Deville?
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Can anyone offer advice on ISC ticking issues w/my 1990 Deville? in Past Cadillac Vehicle Discussion; I have a 1990 Cadillac Sedan Deville with a new ISC Motor installed. Whenever I shut off the car, the ...
    M3GATR@N's Avatar
    M3GATR@N is offline Cadillac Owners Fanatic
    Automobile(s): 1990 Cadillac Sedan Deville
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    I have a 1990 Cadillac Sedan Deville with a new ISC Motor installed. Whenever I shut off the car, the ISC Motor will click/tick for about ten seconds and then stop. Sometimes after it stops I will put the accessory back on and it will tick again. Is there any cause for concern or is this normal?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Re: Can anyone offer advice on issues w/my 1990 Cadi Deville?
    My 92 would click like that but it worked fine. Some say that is a sign of a problem. I wouldn't worry as long as the car idles fine and doesn't stall anywhere.
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    The clicking means that the new ISC motor needs to be adjusted. Do a search here for the instructions...its an easy fix.
    69
    82,163
    Re: Can anyone offer advice on ISC ticking issues w/my 1990 Deville?
    I've heard that is a sign of failure, but I can't swear to it. My '92 did that for as long as I can remember. Never had to replace it.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,464
    It's normal for it to move back and forth for a few seconds after you shut the car off and it makes a noise when it does that. If it's making a ticking noise like the plastic gears are snapping against each other there's something wrong.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,564
    Quote Originally Posted by M3GATR@N View Post
    did you follow the special procedure of setting it up after you installed it?
    or did you simply bolt it in -
    M3GATR@N's Avatar
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    1st, I took it the dealer who told me my ISC Motor is failing and it would cost me $450 out the door to have it installed. I bought one for $75 at OReillys and the kid behind the counter popped it in for $50. He adjusted theidle with a screwdriver "by sound", he didn't have an OBD1 RPM meter. It starts up fine but when I turn on/off the ACC it starts ticking. I just hope I don't need somekind of computer reprogramming or if this doesn't get adjusted soon, my car may have further mechanical problem.
    thanks!
    69
    82,163
    He probably adjusted it wrong. It's been discussed many times. You should have no problem finding it with a search.
    Jun 2003
    Canada
    6,464
    He did it wrong. The best place to start with the screw is to set it the same length the old one was and if it doesn't run right follow the proper instructions. For 94/95s it's a whole process thru diagnostics. I think it's different for the older ones.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    The process is identical for all of them, and can be completed without using diagnostics with a DVOM. What you are looking for is a slight gap between the plunger and throttle hammer with the ISC retracted and throttle closed, and a specific TPS value with the ISC fully extended (1.15v maybe? - whatever it is, this spec will set the correct gap while retracted). ISC operation is completely dependent on the TPS angle, so make sure it's correctly adjusted as well. Both need proper adjustment for the system to work correctly.
    M3GATR@N's Avatar
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    1990 Deville 4.5, Need step by step info to adjust new isc motor
    I installed a new isc motor after being told by the dealer it was failing. My car now runs fine, only that the isc motor ticks for several seconds when turning on/off the ACC (you can feel the ticking on the gas pedal too!). I disconnected the battery (reset the computer), also pressed on the plunger until it stalled out (started right up). It feels smoother and is comfortable, Im just concerned about the ticking as this is a new issue. Also, it appears the engine is loping at start up until it gets warm. Any help is appreciated, I got some feedback on my other similar post (replier suggested searching the forums its a common problem) but I cannot get any solid info on the true way to be assured it is properly calibrated. Also, what is the easiest way to get the rpms? Can id do this with the climate control? Thanks for your time.
    69
    82,163
    Re: 1990 Deville 4.5, Need step by step info to adjust new isc motor
    Press on the plunger until it retracts. When it bottoms out, unplug the ISC motor. Adjust the plunger to a .030 gap between it and the throttle linkage. Plug it back in.
    M3GATR@N's Avatar
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    I know you get this........ how do I know Im at .030?
  16. #14
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    You're going to need a feeler gauge. Cheap, pretty much any parts store.
  17. #15
    M3GATR@N's Avatar
    Jul 2013
    Costa Mesa, Ca.
    41
    231
    where do I hook it up at?
  18. Remove Advertisements
