ELC dryer material
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, ELC dryer material in Past Cadillac Vehicle Discussion; Took appart my ELC dryer and all the desecant "beads" were still loose. Does that mean they will still perform ...
    John Gronberg is offline Cadillac Owners Member
    Automobile(s): 1991 Deville
    Jul 2013
    Geneva, IL
    34
    ELC dryer material
    Took appart my ELC dryer and all the desecant "beads" were still loose. Does that mean they will still perform drying or since they are so old (91 deville) I should refill with kitty litter?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,900
    Re: ELC dryer material
    Your post has nothing to do with Site News or Registration problems. Please read the descriptive text in each forum header to find out what is supposed to be posted there.
    Moved to the proper Deville forum.
    Kitty litter won't work - too dusty - abrasive dust. The filter/dryer is available as a separate maintenance part.
    Look in www.rockauto.com or www.gmpartsgiant.com
    ......... or talk to Chris in Parts at Rippy Cadillac over there >>>>>>> tomorrow morning, business hours EDT.
    68
    81,920
    Can't you just throw that desiccant in the oven to dry it out and rejuvenate it and then reuse it?
    Feb 2006
    55,900
    Trouble with that is, if the existing dessicant is full of snot, even oven drying won't restore the airflow characteristics of the dryer canister.
    The OP says his canister beads are still loose - he could probably get away with an oven cook - 30 minutes at 200.
    68
    81,920
    Worst case scenario, couldn't the desiccant be washed off, then heated, dried and reused?
    Feb 2006
    55,900
    Not sure, Ranger - I would guess the silica gel would simply melt ?????? All the little packets that come in electronics equipment - "Do Not Eat" - that's the dessicant used in the filter/dryer.
    The exhaust feature in the ELC solenoid head is supposed to "blow down" the dessicant canister upon an exhaust command in order to dry it - obviously it doesn't work forever.
    68
    81,920
    If it's the same stuff I'm thinking of, I don't think it will melt. Read the description of this product. I've used it for years. Come to think of it, it probably needs to be "baked".
    http://www.ebay.com/itm/Gun-Safe-Deh...-/180387087876
    Feb 2006
    55,900
    Same here - I heat it all the time - just don't wash it.
  11. Remove Advertisements
