deville 1997 problem with Air suspensions please help
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, deville 1997 problem with Air suspensions please help in Past Cadillac Vehicle Discussion; my Cadillac DeVille 1997 has a problem with air suspension ... rear part is still very up. Dampers are hard ...
    bumer686 is offline Cadillac Owners Member
    Automobile(s): DeVille 1997
    Jul 2013
    27
    7
    my Cadillac DeVille 1997 has a problem with air suspension ... rear part is still very up. Dampers are hard ride is uncomfortable...which part is bad....please help me
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    Re: deville 1997 problem with Air suspensions please help
    Quote Originally Posted by bumer686 View Post
    your car does NOT have AIR SUSPENSION -
    your car DOES have Electronic Level Control -
    a system that uses rear shocks with built in air bladders -
    that are designed to raise the rear body of the car -
    to maintain proper ride height -
    with additional weight in the back seat or trunk -
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    I expect to find an "exhaust valve" code -
    SuperMidget is offline Cadillac Owners Member
    Automobile(s): 1995 base Deville
    Jul 2012
    34
    35
    rear shocks hold air... from onboard air compressor... might not be the most technical description but i'd say that qualifies as a type of "air suspension"
    but aside from that... where is the ride harsh? front or rear end? does it still run a factory setup with the on board level control or manual fill rear air shocks that you just have to much pressure in?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,148
    The rear shocks use air bladders for rear height control due to extra weight in the trunk or rear seat. The air bladders have no part in suspension or suspension (damping) control.
    bumer686, Study the correct parts of the sticky post just above this thread - "How to pull codes". You car has it's own diagnostic code memory/scanner/reader already built-in. Several components of the ELC (Electronic Level Control) are monitored. That's your starting point.
    As posted, assuming the system is stock, the best discovery would be that a control rod has come off a height sensor (LR or both wheelwells, depending on model).
    Jul 2013
    27
    7
    Diagnostic Trouble Codes is: PCM P0603
    IPC B1552
    SDM B1147, B1148
    TCS C1255
    PZM B1552, B1558, B1982, B1983, B2476, B2719
    MSM B2118, B0856, B1982, B1983, U1300
    the ride is harsh in rear end...I have this problem only two days. Two days ago I disconnected the battery, until then everything was fine. Then the problems started
    69
    82,386
    Codes are meaningless with out their definitions.
    Jul 2013
    27
    7
    so where is the problem then? i dont know
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    Quote Originally Posted by SuperMidget View Post
    and I'd say you were wrong -
    the air bladders built into the rear shocks only raise the body of the car -
    to maintain proper ride height - NOTHING ELSE -
    the rest of the rear shock - the dampening part - does just that -
    dampen the reaction of the spring -
    in other words - it stops the spring from bouncing -
    the SUSPENSION of the car - the part that supports the car - are SPRINGS -
    AIR SUSPENSION systems replace the SPRINGS with air bags -
    and the air bags actually support the car -
    the OP stated the rear of the car is sitting too high -
    and the ride in the rear is harsh -
    that tells me the bladders in the shocks are overinflated -
    there are several possible causes -
    the most common things are -
    defective exhaust valve in the compressor -
    defective ride-height sensor -
    the rod connecting the ride-height sensor
    and lower control arm is disconnected -
    the first two possibilities should set a fault code -
    which is why I suggested checking for codes -
    and as soon as the OP supplies us with the CODE DEFINITIONS -
    we will see what shows up -
    Feb 2006
    57,148
    bumer686, Use the link in the code pull sticky to decipher each posted code - then post each code, its definition, and whether each of your codes is Current or History.
    There are almost a thousand GM DTC's - and we haven't memorized the definition of each just yet ............
    Bookmark this link - you will need it as long as you own the car .................
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    we need the DEFINITIONS of all those codes -
    without them - they are just a bunch of letters and numbers
    Jul 2013
    27
    7
    B1552 Keep Alive Memory (KAM) Error
    B1147 Driver Side Air Bag System Malfunction
    B1148 Pass. Side Air Bag System Malfunction
    B1558 BCM EPROM Checksum Error
    B1982 Device Power Circuit High
    B1983 Device Power Circuit Low
    B2476 Parklamp Fault
    B2719 CTD-Trunk Tamper Switch Fault
    B2118 Front Vertical Sensor Failed
    B0856 Battery 2 Out of Range
    C1255 EBCM Internal Malfunction
    P0603 Control Module Long Term Memory Reset
    U1300 Class 2 Short to Ground
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,856
    OK - none of those codes are related to the ELC system -
    so - now it's "grunt work" -
    first - check ALL the fuses -
    pay particular attention to those labeled ELC - or ALC -
    locate the ride height sensor -
    disconnect the rod from the control arm -
    with the ignition ON - engine does NOT need to be running -
    push the rod UP - this simulates a loaded trunk -
    and should start the compressor -
    next -
    pull the rod down - this simulates an un-loaded trunk -
    and the rear would be sitting too high -
    this should open the exhaust solenoid -
    and you should hear air being released -
    try that - and report back with your findings -
  15. Remove Advertisements
