25 DTC's 3 are current....
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 25 DTC's 3 are current.... in Past Cadillac Vehicle Discussion; I went to the pull dtc website listed in the link. Found one that works better for me. Type in ...
    1970_347 is offline Cadillac Owners Member
    Automobile(s): 2002 Deville
    Jun 2013
    43
    4
    I went to the pull dtc website listed in the link. Found one that works better for me. Type in the code instead of scrolling through.
    http://www.aboutautomobile.com/DTC
    http://www.aboutautomobile.com/DTC/b3832 This is how to go straight to the code you want the info on
    Lets start with the body codes....
    b1004 Keep alive memory - triggered every time you lose power. No issue here
    B0065 LF Driver pretensioner deployment loop open (airbag? My air bag light is illuminated)
    B1009 EEPROM checksum error (current DTC)
    B0429 Temperature control #3 Rear Circuit range. (current DTC)
    B1327 Device power low circuit
    B1438 IPC high voltage Overcurrent IPC
    B2810 Steering wheel entertainment fault
    B3832 (No idea it doesn't come up anywhere)
    Chassis code time
    C1224 RR wheel signal is zero
    C1228 RR wheel Excessive speed variation
    C1235 RR Wheel Sensor open/shorted
    I get random Service stability on DIC while driving. haven't pulled codes after this happened with it still lit. ABS and SRS lights lit on dash when this happens.
    Bunch of U codes
    If the pop again after clearing I'll pipe up again on here about them.
    U1000 (current DTC)
    U1016
    U1300
    U1301
    U1713
    U1714
    Powertrain time
    P0300
    P0171
    P0174
    All related to the bellows and intake gaskets I just replaced.
    P1381 Misfire detected. has something listed about the brake module....
    P1189 Engine oil pressure switch circuit.
    P0101 Maf sensor
    P0121 TP Sensor circuit insufficient activity
    that should be all of them.
    The car sat for months before I bought it. I have driven it a little over 50 miles since I fixed the engine.
    I have to order most replacement parts online since Guam parts stores don't stock caddy parts as a rule.
    69
    82,180
    Re: 25 DTC's 3 are current....
    That's like looking for the proverbial needle in the haystack, especially since all but 3 are historical. I'd start from scratch. Clear 'em and see what returns.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    KAM error, EPROM error, multiple U codes, and B1327... Low voltage problem. What is your voltage readout with the engine off? Preferably after being off for at least 30 minutes.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,569
    yep - that explains a LOT of the codes -
    like Ranger suggested -
    clear ALL the codes - and see what comes back -
    Jun 2013
    43
    4
    brand new yellow top optima. 12.6 V
    14.4 while running
  8. Remove Advertisements
