2004 Deville aftermarket headlights
Results 1 to 5 of 5
Like Tree3Likes
  • 1 Post By BlackInjun
  • 2 Post By basscatt
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 Deville aftermarket headlights in Past Cadillac Vehicle Discussion; What are your recommendations for bright headlights with a strong blue tint. Hopefully ones I can order overnight from Amazon....
    BlackInjun is offline Cadillac Owners Member
    Automobile(s): 2004 Cadillac Deville
    Jun 2013
    50
    58
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: 2004 Deville aftermarket headlights
    Quote Originally Posted by BlackInjun View Post
    if you are just looking for "BLUE-BLING" headlights -
    a RICER thing by the way -
    any blue-dipped halogen bulb will do -
    if you want brighter - get 80 watt bulbs -
    if you are talking about the ILLEGAL HID conversion kits -
    I have one word - DON'T -
    Jun 2013
    50
    58
    I had to look that up but thanks for the laugh I went with GE Nighthawk Platinums and still may get something blue for the high beams The low beams seem hid - ish now My shop mentioned HID for 240.00 why not problems with the tech or law?
    (Ricer: from the latin word Ricarius meaning to suck at everything you attempt)
    A person who makes unecessary modifications to their most often import car (hence the term "rice") to make it (mostly make it look) faster. The most common modifications are (but not limited to):
    - Huge exhaust that serves no purpose but to make the car louder
    - Large spoiler on the back that looks like something Boeing made for the 747
    - Lots of after-market company stickers they don't have parts from, but must be cool
    - Expensive rims that usually cost more than the car itself
    - Bodykit to make the car appear lower, usually accented with chicken wire
    - Clear tail lights and corner signals
    - A "performace intake"- a tube that feeds cold air to their engine usually located in areas of excessive heat (behind or on top of the engine)
    - Most of these riced cars (a.k.a. rice rockets or rice burners) are imports; Honda Civics, Accords, Integras, CRXs, RSXs, Del Sols Mitsubishi Eclipses, Lancers, Subaru Imprezas, however there are some domestics such as Chevrolet Caviliers, Dodge Neons, Ford Focus; small, slow, economy cars designed specifically to go slow. Please note that some Supras, Skylines, WRX's and other higher performance imports are designed to go fast, and are therfore not always considered rice. It really depends on the severity of the case.
    Ashtrayhead likes this.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,248
    The HID thing - problem is, unless the car was originally equipped with HID lenses/reflectors, installing an HID bulb in a halogen socket places the bulb in the wrong focal plane - you get the bling color, but the actual lighting pattern is a scattered mess, thus the illegal aspect of the install. You wind up with less light on the road.
    That said, I have no idea of whether or not your model was offered with a HID option - if it was, then a headlamp assembly and maybe wiring harness change would work well.
    Take a look at some of the PIAA Intense White halogens - there are some with a blue tint. They're a 4100K color temperature - sparkly white.
    Original (stock) bulbs are 3100K.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    here is a complete explanation I saved from a previous discussion -
    HID's are NOT designed to work in a reflector type headlight housing -
    they are designed to use a projector lens to focus the light -
    the very best way to describe how this stuff works with "focal plane"
    do you - or have you ever had/used a MAGLITE type flashlight -
    the kind you twist to adjust from a wide flood light - to a narrow beam?
    all you are doing by twisting it
    is changing the focal plane of the glowing element -
    compared to the reflector -
    your cars headlight reflector was made to perfectly match
    the focal plane of the 9006 halogen and 9005 halogen bulbs -
    and of course - neither are adjustable -
    the flashlight adjusted to a pinpoint beam
    represents the perfect match between the focal plane of the bulb -
    and the shape of the reflector - to concentrate the beam of light -
    the flashlight adjusted to a wide beam
    demonstrates what happens to the light beam pattern -
    when a different focal plane is used - all the light is scattered -
    YES - HID's are brighter -
    but because the focal plane is different than the halogen bulb -
    the light is scattered - rather than concentrated -
    and THAT is the reason you can't adjust the headlights
    to put the light on the road -
    and THAT is the reason oncoming traffic is flashing you -
    you are blinding them - and there is NO WAY to change that -
    except to put the halogen bulbs back in -
    your understanding of RICER is spot-on -
    Huge exhaust - FART-CAN-MUFFLER -
    Large spoiler - PICNIC-TABLE -
    after-market company stickers - EACH ONE ADDS 5HP - AT IDLE -
    Expensive rims - IT'S NOT JUST THE RIMS -
    IT'S OVERSIZE RIMS WITH RUBBERBAND TIRES -
    "performance intake" - THAT SUCKS IN HOT AIR -
    you forgot HOOD SCOOPS -
    BlackInjun and CaptRic like this.
  8. Remove Advertisements
