Results 1 to 2 of 2
Thread: '89 Sedan DeVille - problems?
    Sep 2003
    Southern Maine
    3
    I'm looking at purchasing an '89 Sedan DeVille. I was wondering if there are any things I should be on the lookout for?
    I have to put it on a lift Monday and take a look underneath, but I did get a chance to give it a quick once-over, last week. The only problems that seemed significant were the hood struts not working (had to hold the hood up by hand), and a slight ticking from the engine. I assume the struts are no big deal, but I'm slightly concerned about the noise from the engine. It could be from one of the accessories, though. Is there any common cause for a noise like that? (particularly, any cause that is not major, and easy to rule out, so I can hopefully make sure that there isn't a major problem...)
    Thanks for any help,
    Joe
    Jan 2003
    Newtown, PA
    58
    6,472
    Re: '89 Sedan DeVille - problems?
    Disconnect the accessory drive belt and start the engine for a minute (or less) and see if the noise disappears. This is the easiest way to see if a noise is from the engine or not.
  • You may not post replies
