'92 Deville Serpentine Belt
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '92 Deville Serpentine Belt in Past Cadillac Vehicle Discussion; I just finished installing a new Idler Pulley and bought a new Belt for my '92 Sedan Deville. Struggled for ...
    CaddyDeville92's Avatar
    CaddyDeville92 is offline Cadillac Owners Fanatic
    Automobile(s): 1971 Coupe DeVille , 1992 Sedan DeVille
    Jun 2010
    Brooklyn NY
    135
    I just finished installing a new Idler Pulley and bought a new Belt for my '92 Sedan Deville. Struggled for an hour and still couldnt get the new belt on. I followed the belt route diagram thats on the sticker. I get the belt around all the pulleys and when its time to pull back the belt tensioner I cant get the belt to go under the idler pulley. Maybe the belt is too small? Any help would be appreciated.
    bigm57ict's Avatar
    bigm57ict is offline Cadillac Owners Connoisseur
    Automobile(s): 1979 Coupe deVille, 1995 Sedan DeVille (sold)
    Aug 2011
    Wichita Kansas
    44
    1,845
    Re: '92 Deville Serpentine Belt
    Can you post a photo?
    rodnok01's Avatar
    Feb 2012
    NC
    6,631
    Did you check to see if the belts are same size?
    Other thing I can think of I usually have belt on idlers/tensioner pulleys and find a diff pulley to slip on when pull it back. My PA would not go on over the idler but easily went over alt instead.
    68
    81,916
    I would suspect you got the wrong belt.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Wrong size belt, routing belt wrong way, wrong pully size.
    Are you using 1/2 breaker bar to released tension on the pulley?
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Make sure it's the right belt. If is you probably missed the order of how it routes around the different pulleys and the way the pulleys are laid out on those engines you can be looking at the picture sideways and not know it until you're kicking yourself when the belt doesn't fit.
    68
    81,916
    Quote Originally Posted by onecool View Post
  10. Remove Advertisements
