Isopropyl Dry Gas and the 2004 DeVille
Results 1 to 7 of 7
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Isopropyl Dry Gas and the 2004 DeVille in Past Cadillac Vehicle Discussion; Guys, My 2004 DeVille owners manual specifically stated that the owner SHOULD run ethenol gasoline in the car. I've been ...
    DevilleNut is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac DeVille DHS
    Aug 2012
    Endicott, NY
    159
    Guys,
    I've been reading about some of the detrimental effects of ethenol in gasoline. One that was particularly mentioned is that the ethenol will absorb water from the air, but when it does so, it separates from the gasoline and lays in the bottom of the fuel tank where it can contribute to rust and corrosion. One author stated that the solution for this problem is to add isopropyl dry gas when filling the tank. The isopropyl alcohol will absorb water but keep it in suspension so that it is burned along with the gas and will not contribute to fuel system corrosion.
    What I would like to ask is if there is a problem with adding isopropyl alcohol to the fuel in the 2004 DeVille.
    Thanks,
    Bob
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    I'd just run a top tier regular gas and be done with it with no worries. My
    DTS is 13 years old with 174,000 miles and my mom who owned it until 2013 when I got it always ran regular gas from wherever she was when she needed gas, hasn't had any issues.
    Sep 2003
    Metro ATL
    4,854
    Re: Isopropyl Dry Gas and the 2004 DeVille
    Quote Originally Posted by DevilleNut View Post
    If you are reading that "SHOULD run ethanol" into the words on page 5-6 of the Owners Manual, you left out the part that says
    "....GM recommends you use these gasolines, particularly if they comply with the specifications described earlier."
    You will have to search to find gasoline that does not contain ethanol.
    ....One author stated that the solution for this problem is to add isopropyl dry gas when filling the tank. The isopropyl alcohol will absorb water but keep it in suspension....
    What would be the point? Ethanol is alcohol (specifically corn mash alcohol, AKA moonshine).
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    well - just think about that for a minute -
    how much "air" is in your gas tank -
    how much water can that amount of air hold -
    pump gas is 10% alcohol -
    do the math -
    then IGNORE what you read on that site -
    in fact - NEVER GO BACK TO THAT SITE AGAIN -
    the reason people use "HEET" - alcohol - during the winter -
    is that alcohol readily mixes with water -
    and unless there is a LOT of water - and I mean REALLY a LOT -
    that water/alcohol mixture readily mixes with gas -
    and the motor quite happily burns it -
    with a full tank of gas -
    you already have almost 2 GALLONS of alcohol in the tank -
    does it make ANY sense to add another 12 ounces -
    do you think 12 more ounces - on top of almost TWO FULL GALLONS -
    is going to make ANY difference?
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    I hardly ever see anybody buying dry gas anymore. All the gas stations and stores used to have cases of it sitting around. Now they have just a few bottles on a back shelf somewhere. It is no longer needed.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,248
    DevilleNut, Your surfing has turned up yet another bad example of witchcraft and hearsay. Maintain the car, keep it clean, run a Top Tier gasoline and drive happily.
    The sheer amount of gasoline run through your car's fuel tank makes the ethanol-water-separation lie all the more hilarious.
    (Now, if you own a boat with large fuel tanks that will sit unattended or partly filled for 3 - 12 months at a time, then the ethanol water absorption possibility dictates preventive measures - which is why boats have a combination fuel filter/moisture separator installation. Motor vehicles don 't need them .......)
    68
    82,072
    I have about 6-8 bottles of "gas drier" still on a shelf in the garage. Pay for the shipping and it's yours.
  10. Remove Advertisements
