Strut Mount Hardware
Results 1 to 12 of 12
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Strut Mount Hardware in Past Cadillac Vehicle Discussion; Hey Guys, 2 quick questions; one, does the Monroe #902965 Strut Mounting Kit work on the Deville Concours w/ electronic ...
    Goldencletus is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille Concours, 2004 Nissan 350Z Roadster
    Feb 2013
    Gold Country of California
    60
    109
    Hey Guys, 2 quick questions; one, does the Monroe #902965 Strut Mounting Kit work on the Deville Concours w/ electronic ride control? And two, will I need a spring compression tool to replace the front upper strut mounts? Any help will be greatly appreciated!
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,684
    Re: Strut Mount Hardware
    Quote Originally Posted by Goldencletus View Post
    YES
    YES -
    the strut must be removed from the car -
    and disassembled -
    to replace the upper mount -
    Feb 2013
    60
    109
    Thanks!
    Feb 2013
    60
    109
    Alright, bought the strut compressor and the mounting kit (Monroe #902965 from Rockauto, 1/2 the price of O'Reilly), now I'm looking for the post that someone put on this site a while ago with step by step instructions of how to replace these! I've been looking at thread after thread trying to find this post. Even tried Google, I'm sure I'm doing something wrong, but can whoever it was re-post the instructions to this thread please? Thanks,
    SuperMidget is offline Cadillac Owners Member
    Automobile(s): 1995 base Deville
    Jul 2012
    34
    35
    i came across this one searching around last night since my struts came in today i'm putting on my 95 deville this weekend, hope it helps
    http://www.cadillacforums.com/forums...ed-photos.html
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,684
    Quote Originally Posted by SuperMidget View Post
    there are a couple good videos on youtube -
    here is part1 - after the first part - you can easily find part2 -
    http://www.youtube.com/watch?v=LEaevAxA8Gc
    Slknyk is offline Cadillac Owners Member
    Automobile(s): 2001 Deville
    Jan 2013
    49
    I am wanting to replace my front struts (because of the mounts), too. But man, I have never tackled such a job and am nervous.
    Feb 2013
    60
    109
    I've got a slight problem, got everything apart but can't figure out how the tie rod link comes off of the strut. there appears to be either a torx end or allen wrench hole in the end of the bolt. there was a 15mm nut that came off easily but the link wont come free and I don't want to force it. Any help will be greatly appreciated as I'm now past the point of no return!
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    716
    Tie rod link or sway bar link? If its the sway bar link then Look it it closely to see if its aiming slightly up or down, then using a prybar just put a put a bit of pressure on the swaybar to make it level, then tap it out with a hammer,
    If its the tie rod end, once the nut is removed just smack the outside of the housing around the tie rod shaft a few times and it will break it loose.
    I can't recall off hand if the tie rod connects to your strut, some cars are made that way but iirc your car isn't, and its prolly the swaybar link you're referring to.
    Feb 2013
    60
    109
    Thanks Caddy Earl, Bass and Super Midget. It was the sway bar link Caddy Earl, and the pickle fork did the job. Good news is that I got the job done with minimal swearing, no busted knuckles and just a couple of ice cold beers. The bad news is the damn squeak lives on! It did resolve a steering noise however so that's good. Hind sight being what it is, I should have bit the bullet and paid the $375.00 for the Monroe replacements. Maybe next month Thanks again for the help guys!
    Jul 2012
    34
    35
    squeak? what kinda squeak... have you ever taken a grease gun to the old dried out front end parts? or even just some kinda spray lube to all the moving parts?
    these are old boats that have seen alot of hard miles over the years, whatever lube they started with is LONG gone and might just need refreshed
    Feb 2013
    60
    109
    It squeaks going over anything that requires the front suspension to travel (speed bumps being the most prevalent). I have taken a grease gun to all of the fittings and sprayed WD 40 on every moving part that I could find. I thought it was metal to metal on the strut mounts at the body or the large rubber insulator at the top of the strut. Both of those were replaced and the squeak is still present. Someone on this sight awhile ago suggested that it might be sway bar bushings, I sprayed them with WD 40 but it didn't help, I may try to replace them before making the strut purchase.
  15. Remove Advertisements
