Keyless Entry plus rear door lights not working anymore :( '93 Sixty Special
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By onecool
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Keyless Entry plus rear door lights not working anymore :( '93 Sixty Special in Past Cadillac Vehicle Discussion; Please excuse my double post - I've posted this in the electrical section but i figured that this is a ...
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    ExclamationKeyless Entry plus rear door lights not working anymore :( '93 Sixty Special
    Please excuse my double post - I've posted this in the electrical section but i figured that this is a too specific problem to be answered in a generic section.
    I have just tried to replace the factory light bulbs in the rear doors - and apparently a short happened as i put in the LED bulb (rear touched both connectors)
    Now the lights on the rear doors do not work anymore (hot wire rather cold) plus keyless entry stopped working altogether. No reaction on the 'LOCK' buttons inside the door panels as well. Trunk release only works from the button inside the glove box, front door lights still work, as does the trunk light.
    I've checked the fuses below the steering wheel but all seem to be ok.
    Any ideas what could be the problem?
    Thanks!!
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    My 91 deville has fuse under the passages side hush panel, and also on the engine compartment on the firewall.
    if not find your alarm box and follow the hot wire back to where it connects.
    probably the same fuse.
    DReffects likes this.
    DReffects's Avatar
    May 2013
    Germany
    338
    Re: Keyless Entry plus rear door lights not working anymore :( '93 Sixty Special
    THANKS!!! Man, why isn't that fuse box listed in my (German) Manual?
    I've downloaded the '93 Deville owners Manual, in there the Relay Center Fuses are listed... the German Manual only has like 30 pages
