Vibration on acceleration-'03 DTS
Page 1 of 2 12 LastLast
Results 1 to 15 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Vibration on acceleration-'03 DTS in Past Cadillac Vehicle Discussion; Recently noticed a vibration in car from dead stop to about 40. Feel it in whole car. Not sure what ...
    chev600 is offline Cadillac Owners Member
    Automobile(s): Coupe de Ville
    Nov 2010
    58
    7
    Recently noticed a vibration in car from dead stop to about 40. Feel it in whole car. Not sure what it is, and don't even want to guess. Any ideas are welcome. Thanks in advance
    pauldimler93 is offline Cadillac Owners Member
    Automobile(s): 2002 Cadilac Deville
    Jun 2013
    23
    52
    Re: Vibration on acceleration-'03 DTS
    Have you had any work done to the car recently? Hit a pot-hole?
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,884
    Start with the drivetrain - CV joints and front wheel hubs. Do the checks for a broken front center motor mount. Check wheel lug nuts for even torque - 100 lb/ft in a star pattern, 3/4" socket (2-piece lug nuts - flimsy trim caps ???).
    Look through the pages of Cadillac Tech Tips - Discussions, Item Specific. If you're not familiar with moving rapidly around the site, try to Google items of interest: "cadillac forums 2003 deville front center motor mount" - or anything of interest, preceded by "cadillac forums ........".
    69
    82,287
    How old are your tires?
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Low speed would usually be an egg shaped tire.
    Nov 2010
    58
    7
    I need to add that it used a very accesive amount of fuel to drive about 40 miles, almost 5 gals.
    thenaaks is offline Cadillac Owners Member
    Automobile(s): 04 deville
    Jul 2011
    Middle Tennessee
    37
    72
    Brake dragging?
    69
    82,287
    While a vibration or out of balance tire can deteriorate fuel mileage somewhat, it will not drag it down to 8 MPG. THAT is a separate problem. Check for a leaky FPR.
    Mojo88's Avatar
    Mojo88 is offline Cadillac Owners Fanatic
    Automobile(s): 2003 White Diamond DeVille 'Base'
    Dec 2011
    Newport, RI
    65
    347
    Sounds like engine malfunction of some sort to me.
    Feb 2012
    NYC
    50
    1,948
    If it were running rich or missing, there should be a light/code(s).
    rodnok01's Avatar
    rodnok01 is online now Cadillac Owners Master
    Feb 2012
    NC
    6,703
    Only emissions related items set the light o, should check for codes but sounds like a brake dragging to me also. at 8mpg better figure it out quick
    reppinshadyvill is offline Cadillac Owners Fanatic
    Automobile(s): 2003 DTS
    Nov 2012
    Central FL
    34
    205
    If a brake caliper was dragging he should have excessive brake dust on one wheel, the smell of hot brakes after driving and a slightly more sluggish vehicle that doesn't coast like it usually does and it should probably be pulling to one side. If none of these are happening, I would start with rotating and balancing the tires. Cheap and easy first.
    Nov 2010
    58
    7
    A little update, seems to be either a fuel supply or firing issue. Not overheating or anything to do with brakes or tires. After warm up is when it starts. I had the front coil pack replaced before this happened, so I had original coil pack back in. The original coil pack has rough idle, in gear, after warmup. Not sure if it is two separate problems. Maybe a stuck injector, and a firing issue???? Hopefully one of you guys with the experience can help me out. Thank you in advance
  16. #14
    rodnok01's Avatar
    Feb 2012
    NC
    6,703
    Any codes??
  17. #15
    Mojo88's Avatar
    Dec 2011
    Newport, RI
    65
    347
    As stated, check for codes first. Something like this would typically throw a code.
    I'd run a bunch of fuel injector cleaner for your next couple of tanks, and perhaps replace fuel filter too. Also maybe check/replace air filter and spark plugs. Plus, I'd clean the throttle body real good. You can do all this yourself, for not much money or time.
  18. Remove Advertisements
