Lazy MAP Sensor?
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By mc_marto
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Lazy MAP Sensor? in Past Cadillac Vehicle Discussion; This thread is a continuation of the thread titled "Distributor Problem 4.9l" that I started a few days back. In ...
    mc_marto's Avatar
    mc_marto is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Cadillac Sedan deVille
    Aug 2011
    Fort Smith, AR
    27
    516
    Lazy MAP Sensor?
    This thread is a continuation of the thread titled "Distributor Problem 4.9l" that I started a few days back. In that thread I describe a mild hesitation happening on kind of a light acceleration in closed loop. Cadillac_al suggested it might be a lazy MAP sensor. I checked the values through the on-board computer parameter p.0.2 and when the engine is shut off it reads normal atmospheric pressure of 102 kPa = 14.7 PSI - exactly 1 atm. That is normal.
    When I start the engine and it's idling the value jumps down to 38 kPa, when a gear is engaged it reads 41-42 kPa, which I also think is normal since when the engine is idling there is high vacuum, resulting in lower pressure. What I don't find normal is that when I rev up the engine or accelerate in D the value jumps to 45 or 50 kPa, but in less than a second returns to the initial pressure reading of 38 or 42 kPa (depending on whether a gear is engaged or not).
    My logic says, that, if I increase the throttle opening and keep it constant the vacuum should decrease resulting in a higher pressure number (the value of which is going to depend on the actual opening) and the number should stay there and not change unless the throttle opening changes.
    In my case it jumps up but in less than a second it changes to the initial pressure value.
    Does that indicate a MAP sensor going out of range (maybe internal pressure leak), or is there a flaw in my theory?
    I have checked the vacuum supply line for the MAP and there are no leaks present.
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    Service manual has a chart that might prove useful.
    mc_marto's Avatar
    Aug 2011
    Fort Smith, AR
    27
    516
    Re: Lazy MAP Sensor?
    I was trying to look for something like that in mine, but was not able to find it. Any reference of which section it could be listed under?
    Dec 2005
    288
    I look tonight when I am at home.
    Dec 2005
    288
    I lied I'll try to remember to look tonight.
    Doh!!
    Dec 2005
    288
    I forgot to look again but I did a quick Google search. and found this chart. its general but it should work for most cars.
    Dec 2005
    288
    New cart.
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Here's an explanation from the FSM if it helps.
    mc_marto's Avatar
    Aug 2011
    Fort Smith, AR
    27
    516
    Thank you for the charts onecool!
    Thank you for posting this Denis! I read the same thing by the way, but the thing I'm not certain of is whether the reading should stay spot on to where it is without a change in the throttle opening or it could deviate. I couldn't find no information regarding this in the FSM.
    I got an extra MAP sensor off a '94 Deville from the Pick'n'Pull. Well, I've been interchanging my original and the "new" one and tell you the truth the readings are pretty much the same. So, my MAP is probably fine. Maybe there is another sensor chiming in when in closed loop to cause this hiccup condition. And, I don't think it could be clogged fuel injector filters, or the injectors themselves. I have Ohm-ed 'em out and I have 3 injectors with lower resistance than 17 Ohms, but I don't think that rules them out. I have all of the power that I'm supposed to have, and can easily smoke other cars on the road . If it was injectors, I wouldn't have much power, and I would experience hesitation throughout the RPM band, correct?
    dchavezo's Avatar
    dchavezo is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 DeVille
    Jan 2013
    United States
    2,067
    Hey McMarto, you ever find out what it was? I have a similar hiccup (its very slight) and was thinking my map sensor was going bad, but I have the same values reading out as you. (Im going to OHM out injectors soon)
    mc_marto's Avatar
    Aug 2011
    Fort Smith, AR
    27
    516
    Well, I had a distributor problem. The cap and base were misaligned and when I installed a new cap the little notch wouldn't allow it to seat properly. Look for my other thread - Distributor Problem, and you'll find more of an in depth explanation of that issue.
    When I figured that one out I also verified that I had two completely failed injectors and two border line. I replaced all of them as a set a year and a half ago with Bosch injectors off eBay. Search for "Bosch injectors upgrade 4.9l". I got the whole set for around $80.
    A little after that I had an occasional misfire. If I took off a grocery store parking lot, had a very light throttle and let it off for some reason (before I shifted into second gear) the car would buckle and sometimes die. Another symptom was highway shudders through steering wheel and body. Well, one of the new injectors was working intermittently, and it wasn't the injector itself, nor was it the wiring - the old failed injectors had caused one of the PCM drivers to fail. I couldn't find the same transistor so I junk yard PCM did it for me - I got lucky getting an already remanufactured unit for $15.
    I would recommend when you check injectors to do it with the engine fully warmed. The reason - as the engine warms up so do the injectors and that's when failing coils will show up. Start with just listening to the injectors (screw driver or stethoscope) - each one should distinctly click (my last misfire sounded almost like a click but I was just picking some sound from a neighboring injector). If you find a misfire Ohm the injectors, and if they check out fine - start checking the wiring. If the wiring turns out fine - the PCM driver(s) is the problem.
    dchavezo likes this.
    dchavezo's Avatar
    Jan 2013
    United States
    2,067
    Right on, thanks for the quick response. I remember reading about your replaced PCM. My MAP sensor is probably fine. My car runs great its just down to the little things to make it like new.
    When checking the injectors, its just a matter of unplugging the clip and probing the two pin ports for a reading with the engine off, right?
  15. Remove Advertisements
