Speakers for 89 Deville
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Like Tree3Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Speakers for 89 Deville in Past Cadillac Vehicle Discussion; Well, my speakers are getting crackly. All of them. I don't even know what size I need to put in ...
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    Well, my speakers are getting crackly. All of them. I don't even know what size I need to put in there to buy new ones. Does anyone have suggestions? I mostly play rockabilly music, so I don't need any obnoxious super bass crap, and I'd like to spend as little as possible to still get decent sound. Thanks!
    mc_marto's Avatar
    mc_marto is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Cadillac Sedan deVille
    Aug 2011
    Fort Smith, AR
    27
    513
    Re: Speakers for 89 Deville
    Are you using a casette adapter to connect your iPod or similar device? If so, make sure your player's volume is not turned all the way up. Set it somewhere in the middle and recheck. If you supply a louder input to the amplifier it's not going to be able to amplify the signal flawlessly, and you will get crackling sounds.
    Hope this helps
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    I am using a cassette adapter, and yes, I only have it about half way up. They even cracle when I'm not playing any music and just have it on. Well, then it's more like a bubbling sound.
    AElayyat's Avatar
    AElayyat is offline Cadillac Owners Connoisseur
    Automobile(s): 85 Fleetwood Brougham, 90 Brougham 5.7, 05 Deville DTS
    Feb 2004
    So. Cali
    35
    1,135
    Front is 4x6 & rear is 6x9.
    IF yours has the Bose system there are amps (don't remember if its 1 or 2) that you have to bypass when switching to aftermarket equipment.
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    Quote Originally Posted by AElayyat View Post
    Thanks! Now I know what sizes to look for. I'm not sure BOSE speakers even existed in 1989? lol If I had a ton of money, I'd sure buy them now.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Bose was optional in '89. Your car doesn't have leather, it probably doesn't have Bose, which is a good thing in this case.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Faith76 View Post
    yup...GM started using them in 84 on the corvettes and they were available in caddys starting in 85 or 86? They were horrid junk though. No highs, no lows, and midrange wasnt great either. The delco radio with the 5 band eq and the delcosound 4 ohm 6x9s smoked the $1000+ bose system.
    your car has 4x6 in the front and 6x9s in the back btw.
    But if you are getting crackling through the speakers when no audio is put through them, chances are there is something wrong with the head unit (probably just a dirty volume pot due to age/ non use)
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    How can I fix that?
    Quote Originally Posted by cadillac kevin View Post
    Dec 2010
    St. Louis, MO
    6,395
    if that is the problem, you will want to spray the pot (behind the faceplate of the radio) with contact cleaner and work it back and forth
    for speakers, how much are you looking to spend?
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    Not too much. Less than 100 bucks total.
    Contact cleaner as in contact lens cleaner?
    Sep 2010
    East Boston MA.
    29
    26,325
    Electrical contact cleaner. RadioShack.
    Faith76 likes this.
    Faith76's Avatar
    Jul 2013
    Fredonia, NY
    41
    557
    O'm so damn clueless. Sorry. Of course not contact lense cleaner.
    fishnazi likes this.
    Dec 2010
    St. Louis, MO
    6,395
    I have a set of these (well mine are a different model number from 5 years ago) in my 83 lesabre and like them. the cones on mine have turned yellow from sun exposure though (car has sat outside in the sun for 5 years).
    http://www.sonicelectronix.com/item_...dio-db461.html
    as for rear speakers, check and see if yours say 4 ohm delco sound on the magnet (have to remove the carpeted thingy that hides them in the trunk. Those are halfway decent speakers. You won't upgrade them for under $50.
    Faith76 likes this.
  16. #14
    fishnazi's Avatar
    fishnazi is offline Cadillac Owners Member
    Automobile(s): 1987 Coupe Deville
    Jul 2013
    Nor Cal 530
    59
    11
    Kevin, I'm getting ready to replace the rear struts. Gotta take the speakers out, apparently to avoid damaging them/allow room for a wrench. I've gotten as far as "the carpeted thingy." It's still held very firmly by the rear window trim strip, which has no exposed fasteners. Any clue how to remove that without breaking it? Seems like every time I encounter trim like that, if I just attempt to pry it off, something snaps.
  17. #15
    InfomanSS's Avatar
    InfomanSS is offline Cadillac Owners Member
    Automobile(s): 1990 Sedan DeVille
    Apr 2013
    Stow, Ohio
    61
    fishnazi, I have a 1990, but I think that this part should be the same for an '89.
    1. Phillips screwdriver, remove shoulder seat belt trim piece near rear headrest.
    2. 10 mm socket and extension to remove bolt near the same place. The headrest is one, solid piece across the back seat. Lift up the cushion a bit and you will see the bolts at left and right sides. Headrest will just pull forward and out now.
    3. Gently pull rear deck forward. Slowly work it forward and it will come out as well...no fasteners.
    4. Speakers are fully accessible now. Just gently pry the speaker brackets away from the retaining clips. All of this stuff is plastic so be gentle.
    5. Do your strut project.
    6. Might as well put in some new speakers while you are there...most anything is better than stock...even going to Wal-Mart will be an improvement.
    7. Check your third brake light bulbs...easily accessible at this point too.
    8. Put it back together.
  18. Remove Advertisements
