Autozone CV axles last 2 months
Results 1 to 13 of 13
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Autozone CV axles last 2 months in Past Cadillac Vehicle Discussion; What could be wrong other than bad luck with parts. I am ready to replace my 2nd duralast rebuilt CV ...
    EuroCad is offline Cadillac Owners Member
    Automobile(s): 2000 Deville Base
    Oct 2004
    California
    88
    What could be wrong other than bad luck with parts. I am ready to replace my 2nd duralast rebuilt CV axle on the passenger side. I replaced the OEM because the boot was torn. The Duralast went in fine and rode fine for a little while, maybe 1000 miles. Started to hear a clicking when put in reverse and a slight vibration on low speed acceleration while turning left. Just happens to be the speed and turn I make to get to my driveway. Well I replaced it AGAIN and all was well. Now about the same age and I am getting the exact same problem. I have to replace it again. I am doing it by the book. Torque specs and all. Nothing is loose. Front end was just aligned with new bearings and outer TRE's. What would cause this? Can I just blame it on garbage parts?
    68
    81,922
    Re: Autozone CV axles last 2 months
    We don't call them AutoZone Don'tLast parts for nothing. Ain't lifetime warranties great?
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,370
    YEP -
    AutoZone house brand parts are PURE CRAP -
    the absolute cheapest they can get away with -
    sure - lifetime warranty -
    but how many times do you want to replace that same part -
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    If you have changed them that many times, why don't you try a salvage yard once. Do some research and find what years interchange with yours.
    Oct 2004
    California
    88
    I got a salvage yard one. 100k miles on the car, looks fine though. I'm going to try that next weekend. Thanks for the tip. I am sick of replacing this. It is easy now but still blows my Sat. morning. This is the first time I have had issues with aftermarket CV axles. They never last as long, the boots seem to rot and split in a few years but nothing like this. I know Autozone starters and Alternators and house brand relays are complete trash but now I guess the axles too.
    68
    81,922
    Only buy dumb parts from AZ, like fluids, filters, wiper blades, bulbs, etc. NEVER mechanical or electrical parts.
    Oct 2004
    California
    88
    Put the oem used axle on there today. Smooth turns again. Autozone refunded my$$ so that was nice. One thing I noticed the Oem joints are a lot stiffer even used the rebuilds feel really loose and sloppy when moving them around by hand, like much looser tolerances. I hope this one last. I can knock the job out in under an hour now but I am sick of doing it.
    68
    81,922
    Quote Originally Posted by EuroCad View Post
    Practice makes perfect. Been there, done that (on different jobs).
    M5eater's Avatar
    M5eater is offline Cadillac Owners Connoisseur
    Automobile(s): ATS 2.0T RWD FE3
    May 2011
    Suffolk, VA
    29
    4,561
    The autocrap axles I used in the A6 lasted a whole year and <10K miles before the CV boots just dry rotted to the point that they spewed CV grease everywhere.
    I replaced one side with their gold line and the other with another OE rebuild. Only because I'm hoping to be rid of the car before they break, again.
    It's a real shame, because they do rebuild OEM units and they are cheap.
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,740
    Words to the wise. I work at Autozone, get 20% off on Duralast brakes, and I will be buying ACDelco pads.
    Just sayin'
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by CadillacLuke24 View Post
    Just sayin'
    Ditto that.
    I get 10% off for being such a repeate customer.
    With some exception(their cmax and SD pads), their brake pads are not at all worth skimming out on cost.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    IIRC, AutoZone supplies Cardone axles - the same ones you'll get at many of the other major parts houses. The fact that it came from an AutoZone building has nothing to do with it.
    M5eater's Avatar
    May 2011
    Suffolk, VA
    29
    4,561
    Quote Originally Posted by drewsdeville View Post
    If they're Cardone axles, they go to great lengths to rebrand them as their in house axle.
    Their 100% new axles may be cardone, but their remans have their name plastered all over everything.
  16. Remove Advertisements
