2003 DeVille DTS-rough idle at warmup problem solved
Results 1 to 2 of 2
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2003 DeVille DTS-rough idle at warmup problem solved in Past Cadillac Vehicle Discussion; I was going to post the question first, but diagnosed and fixed it instead. I recently had very rough idle, ...
    chev600 is offline Cadillac Owners Member
    Automobile(s): Coupe de Ville
    Nov 2010
    58
    7
    I was going to post the question first, but diagnosed and fixed it instead. I recently had very rough idle, at warmup, in gear. It was the coil packs.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,477
    Re: 2003 DeVille DTS-rough idle at warmup problem solved
    Quote Originally Posted by chev600 View Post
    that is becoming more and more common -
    particularly the rear bank - might be a heat-related thing -
