2000 Deville just dies
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville just dies in Past Cadillac Vehicle Discussion; I have a 2000 Deville, base, with around 100k miles. The car has recently just started to die when I ...
    ggjoy is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    Feb 2011
    3
    I have a 2000 Deville, base, with around 100k miles. The car has recently just started to die when I drive it. I took the car to an indie and he diagnosed the MAF sensor as being bad....had him replace it. All seemed good till a week later...the car died again. Back to the repair shop and this time he replaced the fuel pump. This was about three days ago. Yesterday, the car almost died again. Most of the time the car starts back up fairly quickly, but sometimes I've had to let it sit for an hour or so. Anyone have any ideas?
    70cougar is offline Cadillac Owners Enthusiast
    Automobile(s): 2002 DTS, 70 Cougar conv
    Dec 2009
    Connecticut
    728
    Re: 2000 Deville just dies
    Pull your Diagnostic Trouble Codes (DTC's) & come back & post them along with definitions. See these instructions:
    http://www.cadillacforums.com/forums...odes-dtcs.html
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,575
    Easter egging parts will never fix one of these cars. I doubt that the fuel pump OR MAF was faulty.
    Use the sticky post just above this - "How to pull codes" - if there's a fault serious enough to cause stalls, it will set diagnostic codes in your car's built-in code reader/scanner/memory system.
    I'll guess code(s) P 0335 and/or P 0336, P 0385 and/or P 0386.
    69
    82,161
    I'd put my money on the CKP sensors as well.
    P.S.
    You need a new "mechanic". This guy is just throwing parts at it hoping one will stick.....................at your expense.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,559
    I'm with Ranger - Crankshaft Position Sensors -
    SOMETIMES the bad sensors will NOT throw a code -
    but if you DO get any of the CKP codes -
    here is what you need - and the best prices I found -
    the new ones are gray and black - made in Japan -
    ACDelco 213-1578 - $37.97 - with free shipping -
    from amazon.com -
    and -
    ACDelco 213-1579 - $43.70 - with free shipping -
    also from amazon.com
  8. Remove Advertisements
