Results 1 to 6 of 6
Thread: Svc elect system
    bobstanster's Avatar
    bobstanster is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Deville
    Apr 2012
    165
    Svc elect system
    Have a 2003 deville with Service Electrical System message and pcm p0719 and pcm p0741 and no cruise control .
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,538
    Re: Svc elect system
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    DTC P0719 Brake Switch Circuit Low Input
    DTC P0741 TCC System Stuck Off
    Apr 2012
    165
    What causes that?
  5. #4
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,692
    Quote Originally Posted by bobstanster View Post
    What causes that?
    for the P0741 code - read the thread below -
    it has the most complete explanation - includes pics of the problem -
    http://www.cadillacforums.com/forums...60-1998-a.html
    what causes the P0719 code? - could be several things -
    BUT - it is WHY the cruise doesn't work -
    next time you post codes - you should include the definitions -
  6. #5
    Apr 2012
    165
    Could the stop lamp switch be a problem ?
  7. #6
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,692
    sure - along with the plug - corrosion - faulty wiring - bad ground - etc -
  • You may not post replies
