Codes
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Like Tree3Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Codes in Past Cadillac Vehicle Discussion; I need help with what to do next I got like four codes, any and I mean any help and ...
    xxxxxxxxxxxxxxxRandyCibao Guest
    Codes
    I need help with what to do next I got like four codes, any and I mean any help and info is appreciated, thanks
    Codes are p0443, p0171, p0174, and p0335
    onecool is offline Awaiting Email Confirmation
    Automobile(s): Deville
    Dec 2005
    288
    1) First tell us make and model of car.
    2) Then do an internet search for you'r codes and post back with code meanings.
    3) tell us your car issues.
    basscatt likes this.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: Codes
    http://z-cut.de/US/dtcobd1.html
    Or
    Looks like you are working on OBD2
    http://www.obd-codes.com/trouble_codes/gm/obd_codes.htm
    DTC P0443 EVAP Purge Solenoid Valve 1 Control CKT
    DTC P0171 Fuel Trim System Lean Bank 1
    DTC P0174 Fuel Trim System Lean Bank 2
    DTC P0335 CKP Sensor A Circuit Performance
    Re: Codes
    sorry about that,, I have a 2000 Cadillac deville base model. amunderdog pointed out what the codes are, but the other day I noticed I rough idle when in park neutral or in gear obviously stopped, just thought it was weird since it never did it before. I just need to know what are the best options to go forth on fixing these codes.
    Feb 2010
    Sunbright, TN
    1,530
    Re: Codes
    Me?
    I would be looking for vacuum leaks.
    68
    82,068
    Re: Codes
    A 2000+ engine with a P0171 & P0174 code points to a ripped plenum duct (vacuum leak).
    Caddy-EaRL's Avatar
    Caddy-EaRL is online now Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    670
    Quote Originally Posted by Ranger
    As well as that PVC hose that runs into the manifold. Someone just last week had that problem
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: Codes
    Ranger and Caddy-EaRL are right on the money -
    BOTH the plenum boot and the elbows of the PCV hoses
    are PRIME sources for vacuum leaks -
    the P0335 is also a common problem in the pre 2003 Deville -
    the upper and lower crankshaft position sensors that were black and tan -
    made in Mexico are known to go bad -
    the new ones are gray and black - made in Japan -
    here is what you need - and the best place to buy the parts -
    ACDelco 213-1578 - $37.97 - with free shipping -
    from amazon.com -
    and -
    ACDelco 213-1579 - $43.70 - with free shipping -
    also from amazon.com
    68
    82,068
    Re: Codes
    Yeah, forgot about the CKP code. ALL 2000-2003's will eventually need them replaced. Did mine last summer. ALWAYS replace BOTH.
    Re: Codes
    is there a 'relearn' process I have to do as I have read?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It's almost never necessary.
    68
    82,068
    Re: Codes
    I never did any relearn on mine.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: Codes
    Quote Originally Posted by RandyCibao View Post
    99.99% of the time - re-learn is NOT necessary -
    after replacing the crank sensors -
  16. #14
    Re: Codes
    is there anyway to know if it is necessary or just wing it basically? lol
  17. #15
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,481
    Re: Codes
    NO - but a 1 in 1000 chance is pretty good -
    YES
  18. Remove Advertisements
