new codes new problem
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, new codes new problem in Past Cadillac Vehicle Discussion; well I changed my oil pressure switch last week it got rid of the blinking oil light and stop engine ...
    cadillacjoel23 is offline Cadillac Owners Member
    Automobile(s): 02 sts
    Jun 2013
    NC
    31
    67
    well I changed my oil pressure switch last week it got rid of the blinking oil light and stop engine low oil pressure message...now I have two brand new codes
    p1350-ignition control system
    p1375-24x reference high circit voltage
    any ideas where to start first...im bout ready to give up smh
    69
    82,396
    Re: new codes new problem
    Chances are it's a bad ICM, but can't hurt to check and clean the 4 connectors and the ground first.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,174
    The '97 Deville ?
    Like Ranger posted - pull the coils and ICM and check the connectors and the ICM ground cable. Clean the coil contacts and the ICM base contacts. Use the diagram in my albums to make sure the plug wires are connected to the correct coil towers. Those ICM boards have been known to crack.
    Jun 2013
    NC
    31
    67
    ok ill work on that as soon as I get home thanks for the help...sounds like im not the only one that has encountered this problem
    Jun 2013
    NC
    31
    67
    well glad to say got up under the car looked around the oil pressure switch that I changed...come to find out knocked a wire on the ckp hooked it back up pcm codes gone...finally ses light gone and I can get it inspected...and put my 800 dollar, 200000 mile caddy on the road again after sitting for four years...and the ac works great......
    just wanna thank my cadillac family for all the help
    69
    82,396
    That'll do it. Give it a few days before you have it tested.
  9. Remove Advertisements
