Engine swap question 2000 DeVille
Results 1 to 11 of 11
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Engine swap question 2000 DeVille in Past Cadillac Vehicle Discussion; I have a 2000 base Deville Y engine 80,000 miles. Excellent body, interior, paint. Head gasket blew the day after ...
    Captain Gus is offline Cadillac Owners Member
    Automobile(s): Deville
    Aug 2010
    11
    I have a 2000 base Deville Y engine 80,000 miles. Excellent body, interior, paint. Head gasket blew the day after I spent $1,000 on tires, battery, alignment and replaced both coils $200 a pop.
    Question now is to junk it, repair the heads or replace the motor. Since the 2004 has the new coarse thread headbolts I would like to buy a used 2004 engine. S+Found one with a 3 year warranty for $1,500 delivered. Will it button up to a 2000? Cost to swap? Any suggestions? Kelly Blue book $3,500.
    Thanks!
    Capt. Gus
    Charleston, SC
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Not all '04's have coarse thread head bolts, and the ignition system is different.
    Direct fit engines would be '00-'03, but there's no way to tell if there's an HG issue until it's installed and running in your car.
    If your engine is fine otherwise, insert or stud the block, all 20 bolt holes. Tons of threads on the topic, here, Seville/Eldorado, and the Northstar forums.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    Re: Engine swap question 2000 DeVille
    Repair
    You did not post location.
    There are a few shops that specialize in NorthStar repair.
    I think it around three grand for them to pull the motor repair/replace known NorthStar problems and put the motor back in.
    68
    81,913
    He's in Charleston, SC.
    I'd repair what you have. The devil you know vs the devil you don't.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,875
    Let's hear it for the Lowcountry.
    (ex - Isle of Palms resident)
    Feb 2010
    Sunbright, TN
    1,530
    Capt. Gus
    Charleston, SC
    Thanks
    I missed the fine print.
    Again
    68
    81,913
    Been there, done that
    Aug 2010
    11
    Thanks guys. An addtional $3000 into a 2000 Caddy sounds like throwing money away. I understand I would know what I have as apposed to buying a strange engine, but I would still have $4,500 in recent repairs in a Caddy worth $3,500.
    Feb 2010
    Sunbright, TN
    1,530
    Cadillacs rarely make financial sense.
    What would you purchase for 3k
    Your caddy has another 200k left in it if you care for it.
    cadillac kevin's Avatar
    cadillac kevin is offline Cadillac Owners Master
    Automobile(s): chevy 350 powered 86 FWB, 00 safari h.t. 66 toro, 83 lesabre
    Dec 2010
    St. Louis, MO
    6,395
    Quote Originally Posted by Captain Gus
    A caddy never makes financial sense. I know mine didn't.
    As for spending 3k in repairs, you can't even buy a nice 2000 honda civic for 3k- maybe a trashed out one. I say fix it (besides, a caddy is much nicer to drive than a honda ).
    Sam Trimble is offline Cadillac Owners Member
    Automobile(s): 2001 Cadillac Deville
    Jun 2013
    Arkansas Ozarks
    4
    Have you done the the block test for blown head gasket? My 2001 had most of the symptoms but it only had a collapsed lower radiator hose. I put one on with a wire in it and I have no problem now.
    Quote Originally Posted by Captain Gus View Post
    Thanks!
    Capt. Gus
    Charleston, SC
  14. Remove Advertisements
