89 Cadillac Deville A/C problems
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 89 Cadillac Deville A/C problems in Past Cadillac Vehicle Discussion; My 89 Cadillac Deville A/C compressor does not come on. The car gives me the fault codes of F-15 & ...
    89caddev's Avatar
    89caddev is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Deville
    Nov 2012
    Arkansas
    48
    12
    Unhappy89 Cadillac Deville A/C problems
    My 89 Cadillac Deville A/C compressor does not come on. The car gives me the fault codes of F-15 & F-32. Please Help.
    68
    82,057
    Re: 89 Cadillac Deville A/C problems
    Tell us what F15 & F32 mean and we may be able to help. No one has the codes memorized. I suspect you are low on refrigerant.
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    F15 (Sunload temperature sensor or circuit fault) & F32 (Electronic Control Module-ECM to Body Control Module-BCM fault - loss of communication. Just had the system changed over from R-12 to R-134 (NO LEAKS & FULL) by GM certified Tech. The car has held these same codes F15 & F32 since 10-1-2012. Have tried clearing codes numerous times by using the climate control panel but return during the next ignition of engine. The fuel data center panel seems to read 0 at all times of car operation. Is it possible that it's linked to the codes F15 & F32 ? Thank you for any help.
    68
    82,057
    The fuel data center may be related to the BCM fault.
    I don't recall the '89's having a sun load sensor, but I could well be wrong.
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    They sure did. Not sure how far it goes back, but all of my '80's FWD's had one. I would think it's necessary on any car with electronic climate control - else it wouldn't function very efficiently.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    IIRC, the first sun load sensor in a Cadillac was in the '85 Deville.
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    I've located the outside temp sensor & in-car temp sensor but not the sunload temp sensor which I read tells the A/C compressor to engage or disengage. I asked Cadillac dealership parts dept. about sunload sensor & they sold me the outside temp sensor. Please help if possible.
    Sep 2010
    East Boston MA.
    29
    26,325
    The sun load sensor DOES NOT trigger the A/C compressor, it effects HVAC airflow and fan speed.
    The sensor is on top of the dash pad/defroster grille. It looks like a small, smoked plastic dome.
    68
    82,057
    Cadillac has had electronic climate control since at least 1971. That's the earliest I remember, but probably earlier than that and I can assure you that there was no such thing as a sun load sensor in those cars (and they functioned quite well). I will admit that I do not remember when I first saw it though. I think it may have been in my '92. Don't remember one in my '81, '83 or '85 Eldo, but wouldn't swear to that.
    Like MC said, the sun load sensor has absolutely nothing to do with engaging or disengaging the compressor.
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    What would be the reason for F 15 code - (Sunload temperature sensor or circuit fault)?
    I'm not having problems with blower/fan speeds they work fine. I removed the defroster grille & dash pad with no luck locating plastic dome.
    Sep 2010
    East Boston MA.
    29
    26,325
    A015 is the sun load sensor code. Are you sure you're getting an F code?
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    100% - first F15 then F32 then F.F15 then F.F32 then clear the codes then 0.0 then 7.0 then select auto & key off.
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    Please help if possible it's heating up here in Arkansas.
  16. #14
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Both terminals of the sun load sensor connect to the BCM. I'd concentrate on getting your display to working first and then the AC. Both of those codes relate to the BCM. I'd swap out the BCM next. BCM's have been known to cause all kinds of eratic behavior.
  17. #15
    89caddev's Avatar
    Nov 2012
    Arkansas
    48
    12
    The climate control panel display works fine. Its the fuel data center panel that reads 0. Which I did switch the BCM out and all panels read out some language not from this world so returned the old BCM & clean prom terminals. Company tried to stick me with a no return on electronics. Just trying to find this sunload sensor that's giving a code F15 (Sunload temperature sensor or circuit fault). Please help locate.
  18. Remove Advertisements
