2001 Dts Starts but will not engage Drive or Reverse
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2001 Dts Starts but will not engage Drive or Reverse in Past Cadillac Vehicle Discussion; Caddy isnt engaging gears. It will shift into drive or reverse but the selector still says |P| . I realize ...
    mrd05d is offline Cadillac Owners Member
    Automobile(s): 2000 Cadillac DTS
    Nov 2012
    30
    14
    Caddy isnt engaging gears. It will shift into drive or reverse but the selector still says |P| . I realize that this is most likely a neutral saftey switch however when looking in alldata I could not find this switch. I looked online and found that it may instead be the internal mode switch? What is involved in this fix? I couldn't find much in alldata as far as getting to the part and swapping it out. I found that there is a relay as well? What does this relay do?
    Thanks in advance.
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,528
    Re: 2001 Dts Starts but will not engage Drive or Reverse
    "It will shift into drive or reverse"
    So you can drive it to and fro?
    or
    No matter what you do with the shifter it stays in park?
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    49
    1,948
    The car should still have some sort of engagement & movement if it were the IMS.
    If the car is still locked in park when the shifter is moved, it's a cable or linkage issue.
  5. #4
    Faith76's Avatar
    Faith76 is offline Cadillac Owners Enthusiast
    Automobile(s): 89 Sedan DeVille, 90 Fleetwood, 94 Fleetwood Hearse
    Jul 2013
    Fredonia, NY
    41
    557
    This is probably a really stupid, newbie answer, but here goes: This happened with our 59 Continental and it was out of transmission fluid.
  6. Remove Advertisements
