water pump
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, water pump in Past Cadillac Vehicle Discussion; 99 deville water pump replace cant get pump out it has a bent tab what can be done ---------- hit ...
    sacvo1999 is offline Cadillac Owners Member
    Automobile(s): Mac and Betty silver and pearl 99 devilles
    Jul 2012
    Q.C. AZ
    23
    water pump
    hit it with a hammer till you feel better hahaha your screwed
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,209
    Re: water pump
    The pump unlocks with great force - turned clockwise. Remember the location of the odd tab when it comes out - lock it in with 73 lb/ft of torque in a counterclockwise direction, with the pump seal ring wet with raw coolant.
    If the tang(s) are so bent as to prevent removal the entire water crossover must be removed. Off, repair, on is a 2 day job.
    Pictures in my albums as well as in Cadillac Tech Tips.
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    I know but the socket just spins and spins only 1 tang is bent and its just barely
    68
    82,064
    Re: water pump
    Sounds like you are using one of the cheap stamped steel sockets.
    You may need the WP socket hold down bracket and an impact gun. A few short bursts usually does the trick.
    Feb 2006
    56,209
    Re: water pump
    Water pump capsule socket = You get what you pay for.
    Unless you cut/welded it yourself from steel pipe or paid $65++ it will fail now or in a couple of uses.
    68
    82,064
    Re: water pump
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    yea I got the socket from the part store as a loaner and I noticed the teeth are rounded so
    i think this is a job for the caddy shop due to the fact i don't have the time energy or impact tool to fix
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Find a good independent shop.
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    yea im gonna thank you guys
    Sep 2010
    East Boston MA.
    29
    26,325
    What part of the country are you in? Someone might be able to recommend a shop.
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    im in Arizona does any body know where I can get the hold down bracket off the internet
    Feb 2006
    56,209
    Re: water pump
    Probably no such thing by itself. Either fabricate one yourself or look for the manufacturers that make the whole rig.
    Google "cadillac northstar water pump removal socket set"
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    water pump was fixed at a shop here in town because someone hit it with a hammer and bent the tabs with a screw driver hahahaha
    but now I have a very troublesome overheating issue and I know everyone is going to say HEAD GASKETS HEAD GASKETS and I am thinking RADIATOR RADIATOR and the reason I say that is that the water pump was welded in with more calcium the a jug of O.J. im thinking a good old rad flushing ?????
  16. #14
    68
    82,064
    Re: water pump
    Why was the WP fixed instead of replaced?
    What came first, the overheating or the WP repair?
    Check the coolant level. It frequently needs to be topped off once or twice after cooling system service.
    Check the purge line.
    If neither is the problem and you are still overheating, then do the block test after an overheat episode to check for a HG failure.
  17. #15
    Jul 2012
    Q.C. AZ
    23
    Re: water pump
    the water pump was replaced not fixed the over heat happen frist water pump housing was leaking fluid all over so I replaced seals on housing thermostat and water pump and she still over heats never did that and i have her had almost 9months now I will check purge line next
  18. Remove Advertisements
