94 DeVille rear shock question
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 94 DeVille rear shock question in Past Cadillac Vehicle Discussion; Bought Gabriel replacement air shocks model number G56664. But, I noticed that although the shock has the air inlet just ...
    pooneee is offline Cadillac Owners Member
    Automobile(s): 94 sedan deville
    Aug 2009
    48
    17
    But, I noticed that although the shock has the air inlet just like the original ones, they do not have the plug in on top of the threaded portion on top of the shock. I assume those wires are the sensor wires for the ride height.
    Is there an aftermarket replacement shock that has the proper sensor wire hookup?
    Regards,
    Poone.
    SuperMidget is offline Cadillac Owners Member
    Automobile(s): 1995 base Deville
    Jul 2012
    34
    35
    Ride height is set by a lever on the suspension at the rear driver side tire I do believe
    Aug 2009
    48
    17
    Re: 94 DeVille rear shock question
    Quote Originally Posted by SuperMidget View Post
    So what is the purpose of the wires that are plugged into the top of the original shocks?
  5. #4
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,253
    Quote Originally Posted by pooneee View Post
    the ACTIVE suspension had variable valving
    within the rear shocks and front struts -
    this allowed the shocks/struts to vary the ride from stiff to soft
    you now have PASSIVE rear shocks -
    with a fixed - non-variable valve - so the ride is always the same -
    does not go the the stiff mode any more -
  6. #5
    Aug 2009
    48
    17
    Will I continue to get the "Service Suspension System" message after installing these new shocks?
  7. #6
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    50
    655
    Seems you have the wrong shocks. You either need the right ones, or need to put a resistor into the wire connector.
  8. #7
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,253
    YES -
    but you can "fool" the electronics
    into thinking the active is still there - and working -
    the later models were real easy -
    simply a 4.7K ohm resistor to each old connector -
    REMEMBER - NEVER FORGET THE K
    WHEN TALKING ABOUT THE RESISTORS -
    RIGHT JIM?
    I think the older models requires a relay mounted in the trunk -
    I had to do that on my 95 Deville -
    do a search in the TechTips forum -
    "DEVILLE SUSPENSION ERROR RELAY" - or something similar -
  9. #8
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,423
    Some of the places that sell the rear shocks also have the different relay or another part to go with them to trick the computer into thinking it still works. I think basscat is right that on those it needs more then a rsistor because the computer is looking for feedback.
  10. Remove Advertisements
