Oxygen Sensor - P0141 & P0036
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Oxygen Sensor - P0141 & P0036 in Past Cadillac Vehicle Discussion; Hello. I have a 2000 Deville that has the following current codes: P0141C HO2S Heater Performance Bank 1 Sensor 2 ...
    steve1123's Avatar
    steve1123 is offline Cadillac Owners Fanatic
    Automobile(s): 2000 Deville, 1999 STS
    Nov 2008
    Windsor, Ontario, Canada
    28
    115
    QuestionOxygen Sensor - P0141 & P0036
    P0036C Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
    I'll reset them and they'll reappear fairly shortly (anywhere from a few minutes to a couple hours of driving).
    I've done some research on this great forum and would like to confirm that "Bank 1 sensor 2" is the sensor on the passenger side - post catalytic converter.
    I believe the following part should be the correct replacement?
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    Thank-you in advance for any assistance.
    68
    82,081
    Re: Oxygen Sensor - P0141 & P0036
    Correct, B1S2 is the post CAT sensor.
    steve1123's Avatar
    Nov 2008
    28
    115
    Excellent. Thank-you.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,261
    FWIW, In the 2000 and later Northstar FWD setups,
    B2S1 = left (front) bank exhaust collector sensor
    B1S1 = Right (rear) bank exhaust manifold top center
    B1S2 = After-cat sensor.
    When removing heat shields and replacing O2 sensors do NOT kink or twist the O2 sensor wiring pigtail.
    steve1123's Avatar
    Nov 2008
    28
    115
    Quote Originally Posted by Submariner409 View Post
    Understood. Thank-you very much!
  8. Remove Advertisements
