Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Adding STOP LEAK to 2004 Cadillac DeVille Coolant
    DevilleNut is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac DeVille DHS
    Aug 2012
    Endicott, NY
    159
    Guys,
    I've read on this forum that it is a good idea to add a STOP LEAK product to the coolant in the Northstar engines to help prevent head gasket leaks. I was going to have the coolant in my 2004 DeVille changed and I called the dealer to ask them what product should be used for this. The service manager told me that by 2004 the coolant leak problem had been fixed and adding the STOP LEAK was no longer necessary.
    Do all of you agree that this is no longer necessary, or is the Cadillac service manager a casualty of wishful thinking?
    Thanks,
    Bob
    dusty256 is offline Cadillac Owners Fanatic
    Automobile(s): 1996 sedan deville
    Feb 2013
    62
    188
    Re: Adding STOP LEAK to 2004 Cadillac DeVille Coolant
    Stop leak tabs are not needed . Been discussed a lot on here that they where originaly used to stop Nuance leaks .
    Just keep the coolant changed every two years .
    69
    82,284
    I don't know where you read that, but it was NOT on this forum. There is NO snake oil (in any form) that will prevent HG failure. Least of all the sealant tabs that GM used to use. The service manager was right.
  5. #4
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The sealant tabs were intended for "nuisance leaks", and they're not used anymore, as they clog small coolant passages.
    DO NOT pour any type of block seal product into the system.
  6. #5
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,701
    I have been on this forum for quite a while -
    and I can say I have NEVER heard a legitimate source -
    EVER - recommend ANY stop-leak product -
    to PREVENT OR CURE a head gasket failure -
    DO NOT USE IT - EVER -
  7. #6
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    You sure didn't read that - from any credible source (including the latest GM TSB's) - in any Northstar forum in CF.
  8. #7
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,748
    Old post maybe?
    Stop Leak of any kind is a bad idea. The only thing it consistently does is clog stuff.
  9. #8
    Feb 2013
    62
    188
    I think the maintance tips should be changed
    it still shows this
    Changing Coolant and Using the Correct Number of Tablets (check this discussion for references) (more) (more) (more) (more) : (back to the top)
    The manual will show three of the GM coolant supplement pellets for the Northstar. The 4.x engines were recommended for six of them due to the greater chance of an internal leak of coolant directly into the oil. I always recommend six of the GM coolant supplement pellets / two tubes of the BarsLeaks golden seal powder for either engine. It just provides extra protection against leakage and will not hurt a thing.
    A good time to drain and refill the system with fresh 50/50 DexCool/distilled water is when the 5-year/100K life of the DexCool from the OEM fill is near....
    The water pump will be the easiest one you have ever changed...hard to believe the dealers can somehow justify charging $570 to change one - which is about $450 profit, I would say... With the special tool it's a snap. Remember that the water pump cartridge is removed by turning it clockwise as viewed from over the left front fender looking into the water pump cavity from the backside after removing the cover. It is installed by turning the special tool counterclockwise...a "left handed thread" install. When the old pump is out remember the o-ring seal that is in a groove in the water crossover casting. Look inside the housing when the water pump is out and you will see it. Put a new o-ring in the groove (should be in the kit with the pump) and make sure it is seated and lubed with antifreeze when installing the new pump.
  10. #9
    SUPER LAC DEVILLE's Avatar
    SUPER LAC DEVILLE is offline Cadillac Owners Enthusiast
    Automobile(s): 1998 Cadillac Deville
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by DevilleNut View Post
    Guys,
    Thanks,
    Bob
    I tried it
    Doesn't work
    Think it made it worse
    Eatn twice the coolant now as oppose to before I used it
    Jus a waste of $$$ & a BAD IDEA
    Sent from AutoGuide.com Free App
  11. #10
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Quote Originally Posted by SUPER LAC DEVILLE View Post
    I tried it
    Doesn't work
    I've never ridden in a car with you, but if I had to guess, I would say your foot made it worse.
  12. #11
    Aug 2012
    Tampa Florida
    38
    854
    Quote Originally Posted by Aztec ETC ECS View Post
    I'm not sure why u would say that...
    I don't race my Deville,
    Aside of gas prices... It's a Cadillac, not a hot rod...
  13. #12
    Feb 2012
    NYC
    50
    1,948
    OK. My bad.
  14. #13
    Feb 2006
    56,868
    Quote Originally Posted by dusty256 View Post
    it still shows this
    You certainly did an "about face" from your Post #2 (which was - and still is - correct info). Remember - the 1996 service manual was printed in 1995 and edited in 02/96. GM advice on coolant tablets in the Northstar has/was changed in 2004 and a couple of times later. My 2002 service manual says to use 3 crushed tablets in the lower hose at coolant exchange - but that, too has changed. I have used NO tablets since 2005 and my engine uses not one drop of coolant in 2 years. Our basic advice, based on experience and GM recommendation, is that if you had no nuisance weeps prior to a coolant exchange, you don't need to install the tablets/powder. Why risk clogging a coolant passage or heater core ?
    The stuff in question is Bar's Leaks tablets #HDC or the equivalent powder #G12BP. Google "bar's leaks product sheet". It's ground up ginger root, walnut shells, other organic fibers and a water pump seal lubricant (not needed with DEX-COOL). It works by building a "beaver dam" at a small weep point. Will it do anything for suspected failing head gaskets ?? NO !! (That's "NO !!!")
  15. #14
    Aug 2012
    Endicott, NY
    159
    Guys,
    Thanks for all of the replies. I asked this question because:
    1) A forum that I read on the Northstar engine (I thought there was a link to it from here) stated that stop leak should be added to the coolant to help prevent a leaking rear head gasket.
    2) A television auto program showcased a liquid product by Bars Leaks, and the hosts of the show specifically stated that it helped to eliminate coolant leaks from rear head gaskets in the Northstar engines.
    Sounds like most of you side with the dealer, so that's the way that I'll probably go.
    Bob
    Dusty,
    Thanks for the info on changing the water pump. Where does one buy this "special tool" for doing the pump change?
    Bob
  16. #15
    Aug 2012
    Tampa Florida
    38
    854
    [/COLOR] Where does one buy this "special tool" for doing the pump change?
    http://www.ebay.com/sch/i.html?_odkw...+STAR&_sacat=0
    http://www.ebay.com/itm/WATER-PUMP-R...item3a81cb32c2
  • You may not post replies
