Adding STOP LEAK to 2004 Cadillac DeVille Coolant - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Like Tree8Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Adding STOP LEAK to 2004 Cadillac DeVille Coolant in Past Cadillac Vehicle Discussion; Generally, nobody blindly sides with "the dealer". GM has changed their overall recommendations for nuisance leak prevention. The tablets were ...
  1. #16
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,897
    Re: Adding STOP LEAK to 2004 Cadillac DeVille Coolant
    Generally, nobody blindly sides with "the dealer". GM has changed their overall recommendations for nuisance leak prevention. The tablets were added on the assembly line to prevent possible nuisance weeps and thus avoid warranty comebacks. The tablets were NEVER used by GM as a possible head gasket leak preventive - NEVER.
    A LOT of us have played with almost every sort of snake oil, goop, liquid, powder, and welding rod on those endless shelves of magic in every parts store on earth and have come to the conclusion that most advertising is purely sales propaganda. Also, the conclusion that a right fair amount of "advice" given in forums is pure flight of fancy, and in some cases can be disastrously wrong. I'll go out on a limb and state that the 20 or so regular "advisors" in these FWD Northstar forums has been there/done that, does a lot of homework, is an active car builder/racer/detailer or any combination thereof.
    Why would ANY sealant product claim or even state that an additive, freely circulating in a cooling system, would have a selective sealing effect (the right ("rear) cylinder head gasket) ??? It may have something to do with the number of Northstars that seem to exhibit failed head gasket symptoms in the vicinity of #1 or #3 cylinder .......... but you sure can't hang your hat on that one.
    Additives and snake oil - Google the word "spiff" and do some homework. Then ask yourself which magic the counter salesman pushes today.
    Google "cadillac northstar engine water pump socket" - and in this case, you get what you pay for. Pictures of the whole enchilada in my albums. That socket is almost 5" in diameter.
    SUPER LAC DEVILLE and Jfarr like this.
  2. #17
    DevilleNut is offline Cadillac Owners Fanatic
    Automobile(s): 2004 Cadillac DeVille DHS
    Aug 2012
    Endicott, NY
    159
    Submariner,
    Thanks for the links. I followed the one to eBay and put one on order. You can never have too many tools!
    Bob
    SUPER LAC DEVILLE likes this.
  3. #18
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Factory service manual (1997) says to use Goodwrench or Havoline DEX-COOL and add three engine supplemental sealant (GM #3634621) pellets to the lower radiator hose.
    I find it odd that the factory service manual would recommend using stop leak but at the risk of experiencing a head gasket or coolant leak on a 98,000 mile car, I plan on using the pellets as well as the proper 50% mix of DEX-COOL.
    BTW, where are the coolant drain plugs on the block?
  5. #19
    Sep 2003
    Metro ATL
    4,854
    Quote Originally Posted by Jfarr View Post
    Good luck finding Havoline branded anything. There are several other labels that are licensed to bottle and sell DEX-COOL with Prestone being one of those. Be sure the container says "DEX-COOL" and not DEX-COOL "compatible".
    The terms 'supplement' and 'stop leak' are not interchangeable. The supplement can not and never was intended to prevent or repair (patch) anything to do with future or current head gasket failure.
    There are no block coolant drain spigots.
    Jfarr likes this.
  6. #20
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    The pellets are designed to stop tiny "nuisance leaks", and will do ABSOLUTELY NOTHING to prevent or repair an HG issue.
    The FSM can't update itself, GM no longer recommends or uses the pellets, as they can clog small coolant passages.
    Coolant type is totally irrelevant. There's nothing special about GM engines or cooling systems that makes them REQUIRE DEX-COOL. DEX was designed to be a long life coolant, which most name brand coolants are now anyway. However, nobody here will recommend you follow the long life DEX or conventional change interval of 5 years. Regardless of coolant type, drain and fill every 2 years, 3 max.
    Block drains are in pre '95 engines only.
    Jfarr likes this.
  7. #21
    68
    81,917
    That is out dated and no longer recommended.
    Jfarr likes this.
  8. #22
    Feb 2006
    55,897
    Post #16, Para. 1 ..............
    The 2002 (02/02 edit) service manual says the same thing. That info is outdated - I have NEVER seen my paper service manual update itself - but if you keep up with the GM Technical Service Bulletins and Service Messages, they are deleted and updated on a regular basis.
    No block drains on your engine - it's in the service manual. Coolant flushing procedures.
    Here's the (outdated) page out of the 2002 Seville GM Helm service manual - cooling section. (You might read the sentence just after the sealant paragraph)
    Jfarr likes this.
  9. #23
    Jun 2013
    65
    Very good info guys!
    Much appreciated.............
  10. Remove Advertisements
