2000 Deville overheating problems
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2000 Deville overheating problems in Past Cadillac Vehicle Discussion; car's overheating, had the thermostat,new housing and surge tank replaced. that was last Dec. overheated again this week. found the ...
    charles720 is offline Cadillac Owners Member
    Automobile(s): 2000DeVille
    Jun 2013
    78
    car's overheating, had the thermostat,new housing and surge tank replaced. that was last Dec. overheated again this week. found the surge tank empty, took almost a gal of fluid. can't find any leaks. checked all hoses,all lines to heater coil, not a drop. nothing in driveway and dont see a drop under the hood..though maybe the water pump, but dont see any indications of a leak thru the hole that suppost to show wear on the pump. I drive about 6 miles to next town and on the way back it starts to over heat. surge tank almost empty. my only thoughts are pump belt slipping nipple on surge tank pluged,our something with the throttle body ...really need some feedback.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Wrong forum, your Deville is FWD. A mod will move your thread for you.
    From what I understand, the engine doesn't overheat until the coolant gets low, correct? If so, that's a good sign. I would suggest renting a cooling system pressure test kit from a major parts store, and pressurizing the system cold to check for leaks. Slow leaks can evaporate in hot engine compartment components before having a chance to create a drip or puddle.
    Jun 2013
    78
    Re: 2000 Deville overheating problems
    tks for info, didnt realize i was on the wrong forum, had a time just figgering out how to get in...rgs
    68
    81,764
    If you recently had that cooling system work done, the engine may simply be purging air from the system. Top it off to the proper level (1/2 full) and see if it goes back down.
  7. Remove Advertisements
