Thanks for allowing me to join - 1997 Deville A/C and other problems - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Like Tree23Likes
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Thanks for allowing me to join - 1997 Deville A/C and other problems in Past Cadillac Vehicle Discussion; Man, you must be new here, I don't think I have ever heard someone here recommend a mechanic! Sounds like ...
  1. #16
    talismandave's Avatar
    talismandave is offline Cadillac Owners Master
    Automobile(s): 1980 Eldorado, 1974 Talisman, 2004 Volvo C70,
    Mar 2012
    Madison WI
    58
    7,894
    Re: Thanks for allowing me to join the Cadillac forum
    Sounds like some fairly minor issues and mean you probably found a good car.
  2. #17
    rodnok01's Avatar
    Feb 2012
    NC
    6,719
    The interior lights will only work when dark outside,there is a flat round sensor middle of dash grille.
    Try them at night and if they only work if you turn them on manually, either the sensor is bad or BCM. Weds updating. Mine would on,y come on when door was closed.
  3. #18
    Jfarr is offline Cadillac Owners Member
    Jun 2013
    65
    Quote Originally Posted by mhamilton View Post
    Good luck with it! Evaporators are not usually a failure item on these cars, more likely the compressor belly seal.
    That's exactly where the leak was. Pressurized the system with 60# nitrogen, bubbles around the compressor seams.
    What replacement compressor do you recommend?
  5. #19
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,180
    Quote Originally Posted by Jfarr View Post
    I got a compressor from Arizona Mobile Air, I think it was a Delphi, along with a new accumulator/dryer. I like them for most all my a/c parts www.ackits.com. Just stay away from 4-Seasons at auto part stores and you'll be fine. I would also change the orifice tube. Be careful--on my Eldo I was sold a white (0.072") orifice, which is incorrect. My car used a yellow (let's say it was beige) 0.062" orifice, and made a huge difference in idle performance. Can't tell the color difference unless you have both pieces next to each other. I would change that, evacuate the system, and charge the specified amount. There's compressor r&r instructions somewhere on the forum, there's an access panel through the wheel well.
    If there's a lot of debris in the orifice, might consider replacing the condenser and flushing the rest of the high side lines.
    Also, after you recharge the system, you might have to clear that 'low refrigerant' code before the compressor will kick on.
  6. #20
    Jun 2013
    65
    Bought the "compressor kit" from Arizona Mobile Air, along with a condensor. Included the orifice tube drier, compressor (aftermarket), full set of "O" rings. I added a Delco inline filter to the liquid line, I've had very good luck with these in the past.
    Removed all the lines, flushed them out with lacquer thinner. Doubt there was over 2oz. oil in the system.
    I assume I can disconnect the battery to reset the codes? Would love to get this thing wrapped up and evacuated/recharged this weekend.
    Really like Arizona Mobile Air, ordered the parts one morning, got them the next. The parts were all GPD (name brand) Shipped from Marietta, GA.
  7. #21
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    57,139
    Let's move this maintenance thread to the proper Deville forum.
  8. Remove Advertisements
