Purge line "hollow Bolt"
Results 1 to 9 of 9
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Purge line "hollow Bolt" in Past Cadillac Vehicle Discussion; Alright guys, not trying to start any new threads on old news, but I've got two questions (I'm sure there's ...
    Goldencletus is offline Cadillac Owners Fanatic
    Automobile(s): 1998 DeVille Concours, 2004 Nissan 350Z Roadster
    Feb 2013
    Gold Country of California
    60
    109
    Alright guys, not trying to start any new threads on old news, but I've got two questions (I'm sure there's a "sticky" or a "thread" on this somewhere, and in 8-10 hours of searching I'm sure I would find it!), on the 98 Concours, I took the beauty cover off to try and find this "hollow bolt" I've heard so much about. What I find is a soft rubber line leading to a multi bend, rigid line headed somewhere under a bunch of stuff that I didn't really don't want to remove. Do I need to remove said "stuff" to get to the infamous "hollow bolt"?
    Second question, I just had the coolant system flushed and re-filled, they said that put the Dex coolant in as the replacement fluid. I just checked the coolant level in the surge tank as I've had border line over heating issues and found the level to be as it was after the flush. Upon closer inspection the fluid is very yellow, not green, not orange. Is this the correct "color" for Dex?
    68
    82,081
    Re: Purge line "hollow Bolt"
    Just follow the purge line from the surge tank to the hollow bolt it is mounted to at the other end. Not sure what (if anything) has to be removed to get to it), but before you do that, pull the other end (cold engine) and stick it in the open surge tank. Start the engine. If you have coolant flow, all is well.
    After a coolant change it is not uncommon for the system to take 2-3 runs before the system purges all the air and the coolant level stabilizes. Check it and top odd as necessary. Remember, the correct level is about 1/2 full.
    Hard to tell what they put in there , but whatever it is will work just fine as long as you change it every 2-3 years.
    P.S.
    The "hollow bolt" is where the U shaped hose is attached with the spring clip at the base of the lift strap.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,263
    From my albums (Community tab ^^^, albums, the red Seville) ------------
    68
    82,081
    If you still can't find it...........................quit looking.
    Feb 2013
    60
    109
    Thanks, The solid tubing on mine after leaving the beauty cover heads under all of the throttle body "gear" and then returns to black hose just prior to the connection of the purge line nipple (a very different route than the photos attached, but at the end of the day, the nipple is in the same place). I didn't realize until after I saw your pics, that I had been looking at the "hollow Bolt" the entire time.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Some years/models have the surge tank on the passengers side, so the path is quite different. Also, your crossover/TB setup is different than the one in subs '00+ diagram.
    Feb 2013
    60
    109
    Good evening gents,
    The purge line is clear, tested the coolant with an old style bulb tester and it read good for -25 f and boiling point of 226 f. Today was really hot (105) and the coolant temp went to 232. Ranger said worry after 230, does anyone think it could be T-stat? Again, no fluid loss, just warm up hills, cools right back down after cresting hills?
    68
    82,081
    My comment on the 230 degrees was a general statement. Considering you where operating in 105F ambient temps I think you have to cut the car a little slack. At 105F the cooling system does not have a lot to work with. It's being stressed and is operating close to it's limits.
    Feb 2013
    60
    109
    That is hot, my thoughts were that the T-stat wasn't opening all the way or that perhaps the previous owner had put some of that "nuisance" leak goop in the cooling system and the circulation would be constricted either way. But as you said, it's working hard and the fact that it cools right back down leads me to believe that it's probably okay. Thanks for the input.
  12. Remove Advertisements
