Results 1 to 7 of 7
Thread: 04 Deville EGR problems
    jkstark is offline Cadillac Owners Member
    Automobile(s): 04 Deville
    Jun 2013
    4
    Hi all -
    So, we've been seeing EGR related codes on a 04 Deville - both a P1404 and a P0404. Replaced the EGR valve thinking that would solve the issue, but nothing...
    I went through a series of checks on the system based on instructions on another site, which was basically checking voltages on the harness. I was able to confirm that the +5V reference signal is available on pin D of the connector. I was under the impression that pin E (red wire) was supposed to have a 12V on it. This is the wire that is defined as the "EGR Solenoid High Control" and connects to the ECM to pin 2 on connector 2.
    I compared to a 01 Buick that has a different engine, but a very similar EGR valve. On that particular vehicle, pin E *is* a 12V supply, but I realize that this is not necessarily the same on the other...
    I do notice a rise in the voltage on that pin when the key is turned on, and the engine is run, but the highest that I was able to get that pin to go to is about 2.5V. If that pin is indeed designed to run the solenoid as I suspect, then the 2.5V is not going to be anywhere near high enough to activate the EGR and the codes would make complete sense.
    Anybody have any thoughts and/or recommendations as to where to look next, or what to test?
    Thanks!
    Kris
    69
    82,272
    Re: 04 Deville EGR problems
    Might help if you tell us what P1404 & P0404 mean.
    Jun 2013
    4
    Sorry -
    P0404: Exhaust Gas Recirculation Circ Range/Perf
    P1404: Exhaust Gas Recirc (EGR) Closed Pos Perf
  5. #4
    69
    82,272
    You probably could have gotten away with cleaning the old one, but I am surprised that replacing it did not solve the problem.
    How long has it been? Did you clear the codes and they returned?
  6. #5
    Jun 2013
    4
    Well...
    I did try to clean the old one, which seemed to have had a bit of stick on the closed position - nothing major, but just enough that it might have caused the issue. Reinstalled that one, and cleared codes. Within about 60 miles, the code was back... Pulled the valve out again, cleaned more thoroughly, including as much as I could of the manifold housing and reinstalled. Again, one of the codes was back relatively soon. Figured that it would be worth trying a new valve just to make sure, but that did not allow the codes to stay off either.
    That's what prompted me to see if the voltages made sense, based on a slightly older Buick with a similar EGR, and instructions also found at easyautodiagnostics. Looking at the schematics for both cars, it appears that the reference high signal comes from the ECM, and was mentioned as a 12V potential on the diagnostics site. On the 01 Buick, 12V is what I get, but on the 04 Caddy, under 1V with engine off key on, and up to about 2.5V with engine on. I *think* that this line is what powers the EGR solenoid itself, with the ground provided from the ECM as well.
    Thinking about it now, I suppose I should really test the voltage across the two solenoid control points, and not one against a ground, but in any case, I wasn't sure if the solenoid high reference should have been +12V at all times or not...
    I'm at a loss otherwise...
  7. #6
    Oct 2011
    8
    I know this is an old thread. I have the same car 2004 Deville DTS. Jkstark, did you happen to find out what the problem was? I have the exact same issue but with only one code PCM P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance.
    I too removed and cleaned the egr valve. It actually looked fairly decent and not excessively dirty inside and out.. The car isn't driven much. Can low battery voltage affect this too?
    Any help from anyone would be great. Thanks
  8. #7
    Jun 2013
    4
    Quote Originally Posted by archinno View Post
    Actually - I did...
    Turns out that, contrary to common sense, the EGR valve can be mounted two different ways... You can rotate the valve 180 degrees, and everything will mount and look normal, but then the vacuum from the engine will constantly pull on the actual valve, and keep it stuck open partially.
    In other words, make sure that the valve is correctly installed... I can't even begin to tell you which way is correct at the moment, but if you think of where the suction is, you should be able to figure out that the valve has to move against that suction. Thus, the side that is closer to the intake manifold has the suction, so the valve has to move open so that the suction from the intake won't be able to pull on it, and it has to overcome the suction to open... (Hope that makes sense...)
    Multiple mechanics never caught that - goes to show how well the valve mounts backwards. If I recall right, the wiring fits better too if the valve is backwards, so common sense would dictate that it is the way it should be...
    Kris
  • You may not post replies
