'93 4 door SedanDeville drivers window stopped working
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, '93 4 door SedanDeville drivers window stopped working in Past Cadillac Vehicle Discussion; Hi I tried doing a search here but could not find info for this model/year Drivers window today ceased to ...
    Team ZR-1 is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Aug 2006
    86
    Drivers window today ceased to roll down, it is closed all the way up
    With volt meter the up and down pins of switch properly put 12 volts when switch is pushed in to apply voltage to either up or down wires to motor
    All other doors windows work from drivers master window switches
    I figured out all needed and removed inner door panel
    When drivers window switch is pushed down I can hear a CLICK somewhere about middle of inside of door each time down button is pushed but the window does not move at all.
    What is common failures for this ?
    Does this model/rear have one of those fast down window controllers and it fails ?
    Any way to more pinpoint if its that, the motor or regulator so I know what to look for or replace ?
    How the heck do you even get between the 2 metal skins to do any repairs, saw a few holes but could barely get my hand in just a little bit
    Thanks for any guidance
    pompste is offline Cadillac Owners Connoisseur
    Automobile(s): 1995 SEDAN DEVILLE-4.9 & 1978 SEDAN DEVILLE-425
    Jan 2007
    1,673
    Re: '93 4 door SedanDeville drivers window stopped working
    When my '95 Deville driver side window would`nt go down about 2 years ago,i took it to my local mechanic and they found it to be a bad window motor.I watched them work on it.He tapped on the old motor a few times,after removing the interior door panel,which caused it to intermittenly work.Apparently,the inner workings of the window motor just wear out.My old window motor was original and a new one fixed the problem.
    I was just happy when the original window motor failed,my window was in the all the way up position too,keeping the elements out.
    Aug 2006
    86
    Quote Originally Posted by pompste View Post
    Thanks for the info
    For the heck of it with door panel off, I knocked about center of inside metal door skin while holding down button and after couple knocks the window then rolled down
    I then ran about 15 cycles of fully open and closed with no problems
    So not sure if problem is the motor or some relay for the fast window down feature
    For now I put the door back together and if happens again I'll at least know what it takes to take the panel out
    Thanks
    Jan 2007
    1,673
    Quote Originally Posted by Team ZR-1 View Post
    Thanks for the info
    Thanks
    You`re welcome.We`re all here to help others.
  7. Remove Advertisements
