2004 DHS Satellite Radio Question
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DHS Satellite Radio Question in Past Cadillac Vehicle Discussion; Hello Everyone - I have a 2004 Deville DHS. It has the Bose System - all components work - aside ...
    lisainacaddy is offline Cadillac Owners Member
    Automobile(s): 2004 DHS
    Jun 2013
    Smile2004 DHS Satellite Radio Question
    Hello Everyone -
    It has the Bose System - all components work - aside from the Satellite Radio - there is a button for this feature - it show's though when I depress the button - "No Satellite Radio."
    Before I go through scheduling an appointment with the local dealership - I am hoping someone from the EXCELLENT forum can suggest how I can determine if "No Satellite Radio" means - no service OR "No Satellite Radio" means - it is not installed.
    Thanks everyone in advance for your consideration to my question and response!
    Oh - the Vehicle was an Estate Purchase - means the original owner is not available to query.
    68
    82,056
    Re: 2004 DHS Satellite Radio Question
    First things first. Are you paying for a satellite radio service? I suspect it means no service found. It IS installed.
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,473
    Quote Originally Posted by lisainacaddy View Post
    Hello Everyone -
    you need to check the RPO codes -
    they list all the factory installed options on your car -
    the RPO list is on the underside of the spare tire cover -
    the RPO code for the BOSE SATELLITE radio in my 02 DHS is
    U2K - S-BAND DIGITAL AUDIO SYSTEM -
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    22
    443
    If I push the PTY button I get the same message however my car has absolutely no equipment for satellite other than the HU. I wanted to install it but I can't even find the wiring harness for it nor do I want to put holes in my roof for the antenna, so I just left it alone.
    Jun 2013
    SmileRe: 2004 DHS Satellite Radio Question
    Thanks everyone for your responses ;O)
    I called XM and asked - they couldn't tell me without the previous owner billing information ( which makes sense)
    I will check the code area - many thanks for that too! Good to know.
    Fully agree about not drilling holes into the interior - not for me either.
    Well, I think after I check the codes - if it is present, I will query the local dealership for additional information -
    If not - I suppose it's standard HD channels.
    Thanks again everyone for your input!
  8. Remove Advertisements
