4T80e troubles
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Aztec ETC ECS
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 4T80e troubles in Past Cadillac Vehicle Discussion; have a 1995 Deville Concours that suddenly dropped out of 4th gear to 2nd gear and only drives forward in ...
    95cadconcours is offline Cadillac Owners Member
    Automobile(s): 1995 Cadillac Deville Concours
    Jun 2013
    59
    4T80e troubles
    have a 1995 Deville Concours that suddenly dropped out of 4th gear to 2nd gear and only drives forward in 2nd now. First code that came up was P094, I changed out both shift solenoids and made sure that the internal wiring was in good shape and connected properly. Cleared all codes and took out for drive, still preforms as it did before repairs but new code is P029. I have removed and cleaned the Vehicle Speed Sensor, verified ohms at 1501 with in proper range. Reinstalled VSS and cleared codes and drove, now have P029 code again and the same drive as original problem. I have looked for loose connectors and bad wiring and found no problems. My research has found that the PCM has put the tranny into a fail safe mode. Anyone have any suggestions? I am 2nd owner of car and it has 123,000 miles on it now.
    69
    82,180
    Re: 4T80e troubles
    When you replaced the shift solenoids, did you order the "kit" and install the support bracket.
    stoveguyy is offline Cadillac Owners Connoisseur
    Automobile(s): 03 STS
    Aug 2007
    mpls mn
    2,528
    I have looked at 10 4t80 trans and not 1 had a strainer that was pushed out of the valve body. I think the belief that the special retainer fixes all issues with the solenoids is overblown. I have seen many without the retainer and some with and all had the strainer in place.
    Jun 2013
    59
    Re: 4T80e troubles
    No I only replaced the solenoids, after the repairs stated I have checked and the original solenoids are still good as far as ohms go and neither were broken or sitting out of position.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: 4T80e troubles
    Quote Originally Posted by stoveguyy View Post
    Only 10?
    Get back to us after 1010.
    Quote Originally Posted by 95cadconcours View Post
    That will only work if you replaced them with the non-updated solenoids. I didn't even think they were available anymore. The old style solenoids are actually the screen retainer. That's why they break.
    "New" solenoids with no bracket installed will allow the screen to pop out.
    Sometimes, the crack in the old solenoid is not so obvious or may not even have one, might just flex with screen pressure on it. It will ohm check but not hold pressure.
    No codes?
    CadillacLuke24's Avatar
    CadillacLuke24 is offline Cadillac Owners Master
    Automobile(s): Alexandra - 96 SDV --- Clyde - 15 Silverado
    Jul 2010
    Wyoming
    26
    5,759
    Re: 4T80e troubles
    He has P029.
    Not that you wanted to hear this, but you may have a harness issue. As in internal wiring harness issue. IF that is the case, you're looking at a $2,000 repair. Make sure all the wiring is snug and clean.
    Feb 2012
    NYC
    50
    1,948
    Re: 4T80e troubles
    Quote Originally Posted by CadillacLuke24 View Post
    He has P029.
    Sorry, was being sarcastic. Workin' on that.
    Again, if you put in "new" style solenoids without the the bracket, there is nothing to hold in the screen. It will come out & dump solenoid pressure.
    Also, "old" solenoids have a tab on them that holds in the screen. The bracket cannot be installed with old ones.
    CadillacLuke24 likes this.
  10. Remove Advertisements
