89 Sedan Deville died at stop light
Results 1 to 8 of 8
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 89 Sedan Deville died at stop light in Past Cadillac Vehicle Discussion; So the other day I was driving down the street, came to a red light, and the the car just ...
    mtadeo1 is offline Cadillac Owners Member
    Automobile(s): 1989 Cadillac Sedan Deville
    Jun 2013
    San Diego
    26
    3
    So the other day I was driving down the street, came to a red light, and the the car just died. Wouldn't turn over, no crank. Then got a tow home and let it sit. Then later on that day I went to start it and it turned over, however there was a little noise kind of like a bearing gone bad, but wasnt too loud. After the start I immediately turned off the car due to the noise. Two days later I went to start again and same thing noise came and ran for a bit then again car dies. Now I try to start and nothing. Not getting any crank at all. I have taken the battery to Autozone, and battery is good, they even put a charge. Next I did the starter. I took the starter off and took it to Autozone and turns out its bad. So I drop $70 on a new starter and put it on thinking it would fix the issue. New starter on, and still... nothing.
    Now I'm stuck. Not sure if its the pump relay, or possible bad carb? Video below of the sound it makes when I try to start.
    Any help would be greatly appreciated. Thanks in advance.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,431
    Re: 89 Sedan Deville died at stop light
    The click sounds like it's the starter trying to work. If it's installed properly it's either not getting the power it needs or something is preventing the engine from turning over.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Sure sounds like the starter's engaging. Do you have a breaker bar and socket to try and turn the engine manually? When's the last time you checked your oil level?
    amunderdog is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 SLS x 2 ---- 1993 Eldorado Sport ----- 1994 Deville 4.9
    Feb 2010
    Sunbright, TN
    1,530
    The starter seems to be making an effort.
    I would pull all the spark plugs and try to crank it.
    If that fails
    I would put a wrench on it and see what it feels like.
    cadillac_al is offline Cadillac Owners Connoisseur
    Automobile(s): 70 Deville 77 Fleet 78 Seville 92 Deville 03 Deville
    Feb 2007
    Maine
    55
    3,310
    Yeah, it sounds like the engine is locked up.
    Jun 2013
    San Diego
    26
    3
    Thanks for the feedback. I sure hope the engine isnt locked up. I'll try to manually move the pulley to see if I can move it around. Next I'll do the spark plug suggestion, then I'll post back and update. Thanks again.
    Jun 2013
    San Diego
    26
    3
    ***UPDATE***
    I took the advice to manually turn the pulley. NO ENGINE SEIZED. After a much frustration I took it in to get it checked out. Turns out a defective AC compressor was keeping the engine from turning over. Once the compressor was replaced all was good. Starts right up, no problem whatsoever. Just FYI, never imagined the AC compressor would prevent the car from starting. No wonder newer cars have the belts separate. Thanks everyone for the input.
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    663
    I've seen water pumps, alternators, belt tensioners, and idler pulleys do the same thing.
  11. Remove Advertisements
