Results 1 to 9 of 9
Thread: low oil pressure...stop engine
    cadillacjoel23 is offline Cadillac Owners Member
    Automobile(s): 02 sts
    Jun 2013
    NC
    31
    67
    any ideas on while stopped low oil pressure message appears and stop engine appears... once I take off it goes away tho... and oil light comes on but oil level is gud?
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The oil PRESSURE message and light have nothing to do with oil LEVEL.
    The problem is almost always a faulty oil pressure switch. Replace with an AC Delco part only.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,868
    Re: low oil pressure...stop engine
    "Low oil pressure - stop engine" is associated with the oil pressure sending switch on the oil filter adapter. if your message apopears while the engine is hot, idling only, suspect a faulty oil pressure switch. Common. 2 hour replacement on a lift or on your back, car up on jackstands. dedicated work. Several recent threads on this in here and in Engines, as well as in Cadillac Tech Tips.
    "Check oil level" is exactly that - the level sensor trips the message at about 2 quarts low - so there's still about 5.5 quarts left in the engine.
    Which car ??? 97 or 04 ??? It sure helps.
    For the Northstar engine keep your oil level at the <== ADD XXXXXXXXXX == highlighted X's. That's exactly 7.5 quarts with filter.
  5. #4
    Jun 2013
    NC
    31
    67
    thanks for the help guys I love learning new stuff about cadillacs...and its the 97
  6. #5
    Jun 2013
    NC
    31
    67
    its the 97 deville sub...and none of the big franchise stores have the ac delco, looks like imma have to order it from rock auto...will the duralast switch work?
  7. #6
    Feb 2006
    56,868
    I personally would not put "Duralast" anything in a dead Briggs & Stratton lawnmower, but that's my opinion.
    Take a look at a NAPA store, or talk to Chris in parts at Rippy Cadillac over there >>>>>>> Business hours, EDT - Wilmington, NC
    Study the entire Cadillac Technical Archive way up ^^^ in the top black bar.
  8. #7
    Sep 2010
    East Boston MA.
    29
    26,323
    Duralast - Garbage.
  9. #8
    Jun 2013
    NC
    31
    67
    lol I didnt know duralast was that bad..I got a change of heart now thanks for the help guys..ac delco it is
  10. #9
    69
    82,284
    Don'tLast is an AutoZone part. They are cheap for a reason.
  • You may not post replies
