1995 Deville - fan relay switch ?
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 1995 Deville - fan relay switch ? in Past Cadillac Vehicle Discussion; Fan relay switch...
    jerry ivery is offline Cadillac Owners Member
    Jun 2013
    Fan relay switch
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,850
    Re: 1995 Deville - fan relay switch ?
    What are you asking -------- and Audio/Video is not the forum for repair and maintenance of the cooling system. Moved to Deville.
    Here's a pre-2000 cooling fan circuit diagram - no "fan relay switch" installed and none needed.
    Fans run all the time when any HVAC function that requires A/C compressor operation is set. When no A/C compressor function is set, fans go to SLOW at 224 degrees and FAST at 236. The engine cools to 213, fans turn OFF and the cycle starts over. Fans are not needed above ~35 mph.
    Jun 2013
    I have 1995 needs to know where is fan relay located
    Feb 2006
    55,850
    I believe the 3 fan relays are on a frame on the fan shroud itself. The maxi-fuse is in the secondary underhood box.
    Owner's manual ? or
    www.alldatadiy.com
  7. Remove Advertisements
