I just recently rebuilt my caddy motor and fired it up and the indication light says I have low fuel pressure to stop motor. I have primed the system and still no pressure. When I was building the motor I put a new oil pump in, so I'm stuck and need some ideas anyone
Your post has nothing to do with Registration problems or Login issues. Please read the descriptive text in each forum banner to find out what is supposed to be posted there.
Moved to the proper Deville forums.
Fuel pressure ??? Oil pressure - the oil pump is driven by friction between the harmonic balancer hub, the oil pump drive sleeve, and the crankshaft machined shoulder. There is a specific torque - degree sequence to get that sleeve properly clamped. Read your GM service manual again, lock the engine flywheel (flexplate) and perform the proper torque/degree procedure on the harmonic balancer bolt.
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
