R-12 Recharge - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, R-12 Recharge in Past Cadillac Vehicle Discussion; Hehe, hind sight is always 20/20. I did learn a lesson though and stocked up on R134a while it was ...
  1. #16
    68
    81,922
    Re: R-12 Recharge
    Hehe, hind sight is always 20/20. I did learn a lesson though and stocked up on R134a while it was cheaper (er).
    Considering it hasn't been touched it in at least 10 years I would that's probably all it needs and it doesn't owe you anything. The problem won't be so much finding a shop that CAN do it as much as finding one WITH R12.
  2. #17
    STS_Seville_Hunter is offline Cadillac Owners Enthusiast
    Automobile(s): 91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
    Sep 2008
    DHS/Palm Springs, CA
    29
    675
    I had no problem recharging a r12 system, two shops where I live do it, cost was $200. Call around.
  3. #18
    aeronca36606 is offline Cadillac Owners Enthusiast
    Automobile(s): 85 Coupe Deville 4.1 V8 & 4.3 V6 Deisel & 1970 Eldorado
    Sep 2005
    East Tennessee
    773
    Re: R-12 Recharge
    If the compressor has been tripped off by the BCM then you probably have almost no Freon left. Make sure that you do a comprehensive leak check before you waist expensive R-12. Once all leaks are addressed then an R-12 charge will be relatively in expensive as it will last for years.
  5. #19
    drewsdeville is offline Cadillac Owners Master
    Automobile(s): 2011 Crown Vic LX, 2009 Chevy Malibu 2LT
    Oct 2004
    Oak Creek, WI
    5,609
    Re: R-12 Recharge
    I've never heard of the mysterious escaping freon theory. I find that hard to believe, considering how many homes out there have perfectly working refrigerators that are well over a decade old - many times half century old freezers in the basement holding last season's game meat. That said, dad's 215k mile '89 still holds the factory R-12 charge, and I've never had another system leak down over time after proper repair... I concur with the above post- if it's empty, there's a leak that needs repair or it will do it again. Find the leak, then recharge.
  6. #20
    13ir14314's Avatar
    13ir14314 is offline Cadillac Owners Fanatic
    Automobile(s): 1967 Eldorado
    Jan 2012
    Minnesota
    21
    443
    Quote Originally Posted by drewsdeville View Post
    If the A/C in a car was made the same way as home appliances there would be far fewer leaks. The home units are sealed with O- rings and bolts they get crimped then welded or soldered making it almost impossible for leaks.
  7. #21
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    Automotive systems do use O rings, crimps, and welded/blazed parts. The components in an automotive A/C system have it MUCH tougher than a home system, in terms of movement/vibration, and heat.
  8. #22
    68
    81,922
    Re: R-12 Recharge
    I do know a guy that once used an old piston type car compressor to run a home A/C system.
  9. #23
    Oct 2004
    Oak Creek, WI
    5,609
    Re: R-12 Recharge
    They sure do, which is why failure rate is much higher. However, the point is, auto or not, a leak is abnormal - if it wasn't, aftermarket component warranties would be pointless and manufacturers would exclude AC from their warranties. A properly working system will never need a charge. Some people will live with a small leak, but it's never normal...
  10. Remove Advertisements
