Hard Shift
Results 1 to 5 of 5
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Hard Shift in Past Cadillac Vehicle Discussion; I have noticed that at times my car shifts fairly hard at times. Not slamming into gear or anything, but ...
    Trench's Avatar
    Trench is offline Cadillac Owners Fanatic
    Automobile(s): 1991 Eldorado (Gone) ; 2001 Seville SLS (RIP) ; 2005 DeVille
    La Salle County
    32
    228
    Hard Shift
    I have noticed that at times my car shifts fairly hard at times. Not slamming into gear or anything, but hard enough to bobble my head a bit. Probably about 2/3 of the time.
    I have no active PCM codes.
    Where would be the first place to check?
    txpiedpiper is offline Cadillac Owners Member
    Automobile(s): 05 deville 97 deville
    May 2011
    Dallas Tx
    41
    15
    Re: Hard Shift
    I've had that same problem in my 05 Deville. No codes either but was told engine mounts might be the cause of my problem by a couple of mechanics. Its a start.
    Aztec ETC ECS's Avatar
    Aztec ETC ECS is offline Cadillac Owners Connoisseur
    Automobile(s): '02 ETC ECS#533, '05 Escalade, '05 AWD Magnum, '74 455 OLDS
    Feb 2012
    NYC
    50
    1,948
    Re: Hard Shift
    That's a tough one with no codes.
    I don't know about the mount thing.
    Is it just the 1-2 & does it feel like a slide-bump? Possibly bad 2nd clutch.
    Or, could be a sticky pressure solenoid. If it's not electrically bad, it won't throw a code or put into limp.
    Trench's Avatar
    La Salle County
    32
    228
    Re: Hard Shift
    Quote Originally Posted by Aztec ETC ECS View Post
    It seems to happen only when increasing from a lower speed. So maybe when engaging 2nd. When it acts up, there is a slight pause and it drops in gear with a small jerk.
    Feb 2012
    NYC
    50
    1,948
    Re: Hard Shift
    That slight pause(slide) & small jerk(bump) may be an indication of a worn 2nd clutch pack or leaking internal seals.
  8. Remove Advertisements
