2004 DTS hard shift
Results 1 to 4 of 4
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 2004 DTS hard shift in Past Cadillac Vehicle Discussion; Bought the car 3 months ago, has 134k miles. Have noticed that once the car gets heated, after an hour ...
    shelly is offline Cadillac Owners Member
    Automobile(s): 1995 Eldorado, 2004 DTS
    Jun 2013
    Lowell, MA
    5
    2004 DTS hard shift
    Bought the car 3 months ago, has 134k miles. Have noticed that once the car gets heated, after an hour or so of nonstop driving, it will start to get a hard shift. Otherwise, shifting is unnoticeable. once I'm driving and this happens, if I pull over and shut the car off for just a few minutes, the problem goes away. the hard shift will come back after continuing on for an hour or so. Weird. Also, when this is happening, I notice that it shifts roughly when I put it in park or reverse. Took it to my mechanic for a quick check...said the fluid looks good and the screen tells that a tranny service was just done. Any ideas at all?
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,343
    Re: 2004 deville DTS hard shift
    check for Diagnostic Trouble Codes -
    if you don't know how - go here and read the ENTIRE post -
    http://www.cadillacforums.com/forums...odes-dtcs.html
    if you have any codes - post them here -
    ALONG WITH THEIR DEFINITIONS -
    Jun 2013
    Lowell, MA
    5
    Just read how to check for codes. Will do that in the morning.
    Jun 2013
    Lowell, MA
    5
    Re: 2004 DTS hard shift
    Just got the codes. There are a few related to the power seats and radio, but here are the rest:
    TTM B1327 History - very low a/c refrigerant warning
    ABS U1056 History - loss of communications with RSS
    PCM P1811 History - maximum adapt and long shift
    IRC U1016 History - loss of communications with PCM
    If you want or think the other seat/radio codes are relevant, I will post them.
    Thanks.
  7. Remove Advertisements
