Coolant level drops
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 21
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Coolant level drops in Past Cadillac Vehicle Discussion; Hi, I noticed the other day that my coolant level (overflow tank) was about an inch below the line, so ...
    r_2016's Avatar
    r_2016 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Lexus LS430, 1993 Deville
    Sep 2005
    Boston, MA
    181
    Coolant level drops
    Hi,
    I noticed the other day that my coolant level (overflow tank) was about an inch below the line, so I added some, then I noticed that it was a little low again the next day. The car was in storage for about 7 years upto about a week ago, and I do know that the caps rubber o-ring is pretty dried out, I am thinking that air might be getting in to the tank. When the car is running the level does not drop, so I don't think the engine is consuming it; there is no coolant in the oil (oil looks good) and there is no white smoke in the exhaust; no check engine light and the engine seems to be running good; the coolant in the overflow looks good and there are no leaks. Is it possible that a bad cap could cause this; I don't know what else it could be. The car is a 93 Deville with 87000. Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    It could be the cap, or a slow leak. Caps are cheap, start there.
    r_2016's Avatar
    Sep 2005
    Boston, MA
    181
    Re: Coolant level drops
    Yes, I found the caps on ebay for short money. Like I said, the caps rubber gasket looked like sh**; it was all dried out, so hopefully that is the issue. I had a similar thing happen with a 97 Towncar; I had the coolant flushed and the next day the coolant was about 3-4 inches below the cold line (it was full when they flushed, I checked), I refilled it and never had any other issues. I am guessing air pocket?
    Sep 2010
    East Boston MA.
    29
    26,325
    I wouldn't even bother ordering online. Get a Stant at a local parts store.
    r_2016's Avatar
    Sep 2005
    Boston, MA
    181
    Stant is a good brand? I will check Napa, Autozone for them. This car is not a daily driver, so I can leave it in garage until I get the new caps. I don't want to cause any issues with air getting sucked into the cooling system driving around with bad caps. Thanks for your help on this issue tho.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,449
    Stant is one of the major manufacturers for those parts. If you want to stick with GM just pick one up at the dealer.
    Sep 2010
    East Boston MA.
    29
    26,325
    Either way, you're talking ~$10-$20.
    r_2016's Avatar
    Sep 2005
    Boston, MA
    181
    Thanks Guys
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    56,193
    Stant, Gates, couple of others. Stant and/or Gates is probably the contractor for some AC Delco cooling system parts.
    (When I replaced the w/p drive tensioner pulley it was a Gates product - and identical in every way to the original equipment pulley that failed. I have a spare Stant surge tank pressure cap and, except for the ID sticker, it is identical to the factory cap. Some AC Delco Professional Platinum spark plugs are made by DENSO in Japan.)
    mc_marto's Avatar
    mc_marto is offline Cadillac Owners Enthusiast
    Automobile(s): 1991 Cadillac Sedan deVille
    Aug 2011
    Fort Smith, AR
    27
    516
    It might be a small leakage besides a bad cap. Since you say the car was in storage for seven years, why don't you drain and refill your coolant? It'll probably need to be done anyway, and just add two of the BarsLeaks tubes in the radiator when you refill the system. I used to have a small leakage that I couldn't pin-point and that was the solution for me.
    Feb 2006
    56,193
    Two tubes of Bar's leaks G12BP would plug up a Sherman tank. If you have no obvious small nuisance weeps, I would advise against using ANY sort of "stop leak"............ and if a leak, wherever it shows up, is enough to cause noticeable coolant loss in a week or a month then the leak needs to be repaired, not BandAided.
    Sep 2010
    East Boston MA.
    29
    26,325
    mc_marto's Avatar
    Aug 2011
    Fort Smith, AR
    27
    516
    As far as I remember there were pellets recommended for use by GM whenever the coolant is drained and refilled. And, there have been threads in the past about it. IIRC the recommendation was six pellets, which will be equivalent to 2 small tubes of Bar's Leaks. And, when you can't find the leaks because they're so small that's the way to go. I wouldn't band-aid if it is a bigger and obvious leak.
  16. #14
    Caddy-EaRL's Avatar
    Caddy-EaRL is offline Cadillac Owners Enthusiast
    Automobile(s): 2000 DTS 194,000 miles, 2000 DHS 203,000 miles
    Apr 2013
    Ky
    51
    669
    Gm no longer recommends the use of gm seal tabs.
    They clog up the system
  17. #15
    Jun 2003
    Canada
    6,449
    Only if you keep adding them or use too much and don't follow the proper maintenance.
  18. Remove Advertisements
