Results 1 to 5 of 5
Thread: 93 Deville "Service Air Cond" error
    r_2016's Avatar
    r_2016 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Lexus LS430, 1993 Deville
    Sep 2005
    Boston, MA
    181
    Hi,
    I just put my 93 deville back on the road after being in storage for some time. When I tried to use the air conditoner today I got an error (the service air cond light would come on for a min, then go out). I am thinking I might just be alittle low on freon; I know the system uses R-12. Does anyone know if you can still get an R-12 system charged, or would it be easier to change to R-134a? Thanks
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    You can still find shops to service R12 systems, but if the problem is low refrigerant, you have a leak, and that has to be addressed.
    r_2016's Avatar
    Sep 2005
    Boston, MA
    181
    Re: 93 Deville "Service Air Cond" error
    Ok, thanks.Someone told me that it is very easy to convert an R-12 system to R-134a; they said that after the R-12 is evacuated from the system, you just fill the system to 80% with R-134a. I know I would have to take it to a shop to have them remove the old R-12, but is this true?
  5. #4
    basscatt's Avatar
    Feb 2004
    Minnesota
    65
    15,681
    Quote Originally Posted by r_2016 View Post
    it's a little more involved than simply changing the gas -
    google RETROFIT R12 TO 134A
  6. #5
    69
    82,262
    Someone told you wrong. It is MUCH more involved and expensive.
    http://autoacrepairs.com/134aConversion.htm
  • You may not post replies
