I have a 99 Deville Concours with 90,000 miles. Three weeks ago, I had the local Cadillac dealership fix the dreaded half case seal oil leak. They fixed that, then I get a call and they say I have a coolant leak. Knowing that these engines run on the warm side, I said yeah go ahead an fix that, as I did not want and head gaskets failure issues and overheating which the car NEVER has. The fixed the supposed coolant leak, installed a new water pump (pre-caution) a new thermostat, hoses and seals. Total bill....$4,600!!
Now 3 weeks later this past Monday, I was sitting in the drive-thru, it was a warm 90 degree day, had the A/C on and I heard a "ding" I looked and the DIC said "Engine Hot - A/C is Off" I looked at the temp gauge (being that I have analog gauges) and it was on the edge of the red line for overheating. I started driving and it went back down to mid-range which is normal. I drove straight to the Caddy dealer and the overheat message was still on there and they seen it.
I get a call yesterday and they say the engine got so hot, it blew the head gaskets and may have warped the heads, and they recommend another engine.
Here is my question, they worked on the cooling system just three weeks ago for which I NEVER had any cooling issues. Should they be held accountable for this as they state they did not work the top part of the engine ref their work in the cooling. I have a meeting this afternoon with the service manager, what knowledge or what can I go in and challenge them on? Am I stuck?? Sorry for the length. Thanks!!
