Could you help me with this car please? 1993 Fleetwood - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 49
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Could you help me with this car please? 1993 Fleetwood in Past Cadillac Vehicle Discussion; Originally Posted by DReffects picked the car up today. pewh... the first 100 miles was VERY different from the test ...
  1. #31
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    Quote Originally Posted by DReffects
    picked the car up today. pewh... the first 100 miles was VERY different from the test drive. the car started stuttering and shaking, refused to accellarate etc. ppp.
    Did you pull the codes?
    I cleared the DTC Error codes and for my complete surprise the Air Conditioning started working for about 3 minutes, then it shut down again. DTC gave the "low coolant" error code. So i guess the AC is just a refill away
    If it's low, there's a leak.
    I've noted a very odd button below the Parking brake (near the footrest for your left foot) you can step on it and every time i do this i can hear a relay click below the glove box. Do you guys have any idea what that is?
    Nothing stock.
  2. #32
    DReffects's Avatar
    DReffects is offline Cadillac Owners Fanatic
    Automobile(s): '93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
    May 2013
    Germany
    338
    Re: Could you help me with this car please? 1993 Fleetwood
    Good news:
    - The AC works after a refill - heating still does not but i guess that's a matter of flushing the system properly.
    - The rumbling noise is a defective catalyst which can be replaced easily
    No news on the "Service SSS" light yet, but i guess i simply need new rear struts. Does anyone know the part number?
    Apart from miiiinor oil leakage and a the engine coolant consiting to 100% of pure water everything seems to be in great condition
  3. #33
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,475
    Get that water out of there and put in proper coolant. These cars were known for neusense leaks when they were new and having straight water in there can make things go bad real fast.
  5. #34
    DReffects's Avatar
    May 2013
    Germany
    338
    Quote Originally Posted by brougham View Post
    Thanks for the info - that's on top of my list now!! Where can i find that coolant drain screw/plug?
  6. #35
    dennis93coupe's Avatar
    dennis93coupe is offline Cadillac Owners Connoisseur
    Automobile(s): 1993 Coupe Deville, 2009 XLR-V 1 of 6 Crystal Red
    Feb 2010
    Orange County, CA
    62
    2,479
    Coolant drain is on the bottom drivers side of the radiator end tank.
  7. #36
    DReffects's Avatar
    May 2013
    Germany
    338
    Perfect, thanks!! :-)
    I've started cleaning btw...:
  8. #37
    Sep 2010
    East Boston MA.
    29
    26,323
    Smokers car?
  9. #38
    Feb 2010
    Orange County, CA
    62
    2,479
    Wow, that was nasty.
  10. #39
    DReffects's Avatar
    May 2013
    Germany
    338
    nope, never been smoked in this car. Never cleaned either i guess
  11. #40
    Sep 2010
    East Boston MA.
    29
    26,323
    Lol, well I guess that could explain it too.
  12. #41
    DReffects's Avatar
    May 2013
    Germany
    338
    So i had the car on a service lift today...
    guess how the catalytic converter looked like from the inside...
    While probing the battery we've noticed something:
    The hot wire from the battery was routed to badly, it touched the spinning part of the alternator. The POSITIVE pole that is. Dude....
    Anyhow... catalytic converter is now empty and back in place. Car drives like a charm. Battery replacement has been ordered, 80 bucks. Apart from the electronic struts and the trunk lid pulldown motor I am good to go Car looks really good from below, especially considering the age. Minor oil leakage but nothing out of the ordinary I think i've made a good deal at this point. Have to spend ~300 on new struts, 80 on the battery, 50 on that pulldown motor. So all in all I am looking at 3.000 EUR *including* the car What do you guys think?
  13. #42
    Jun 2003
    Canada
    6,475
    Yikes on the battery cables!!
    Thaat's not the normal battery cable setup. Follow the cables back to see where all they go. Originally they should have gone to the side post connection, but if those batteries are harder to get in your area that is probably why they converted. The one in that picture does have it.
    Usually the only thing wrong with the power trunk pulldown is the black switch that you see at the very top of it when you look at it.
    From what you've said about prices before it seems like a good deal. It's a lot more then those cars go for around here but you don't have much of a chance to shop around either.
  14. #43
    DReffects's Avatar
    May 2013
    Germany
    338
    It's an original ACdelco battery with connectors both on the side and on top. I guess as the car was 'converted' for switzerland by Cadillac when they shipped it, they've used the top poles.
    The Switch at the trunk lid actually works just fine, the motor inside is dead. I've opened up the casing and found the two cole-connectors hanging around and having a good time. The motor itself works if you put some power to it. I don't know if I have the patience to realign those connectors or just get a new used part... seen one for fifty bucks
  15. #44
    keumnam is offline Cadillac Owners Fanatic
    Automobile(s): 1993 Sixty Special, 1993 Buick Roadmaster Limited
    Jun 2011
    64
    100
    Look exactly like mine except I have a vinyl top and no moon roof. I also have elect seat recline and my rims are a slightly different style (center caps the same though). Paid $950 for it with 140k more or less (can't remember now) and now has 153k miles. Replaced the radiator, idle control motor, and brake master cylinder. Other than that works perfect and I absolutely love driving the car. We also have a 1993 Buick Roadmaster...which is the sister to the Fleetwood Brougham...and it handles entirely different. I love both cars although each have entirely different manners and personalities.
    Quote Originally Posted by DReffects View Post
    Hey Guys,
    as some of you might have noticed i am wanting to buy a fleetwood. I am currently looking at a '93 "Fleetwood Sixty Special" with the 4.9 V8 Engine. From what i understand this car is based on the 91-93 Fleetwood - or is it based on the DeVille? If so, what's the major difference between the "Sixty Special" and the "Fleetwood"? It seems to have the new '93 Fleetwood Exterieur, but has odd looking seats (i don't see any electronic adjusters).
    So is this a RWD Car and has the smaller 205.6 in (5,220 mm) body or the '93 Fleetwood length of 225.0 in (5,720 mm)?
    The VIN is as follows: 1G6CB53B1P4220612
    Could you also please give me some information on the Fuel Economy of the 4.9l V8 engine and the ride itself? I've driven a '95 Fleetwood Brougham RWD, it was awesome and smooth - that's the kinda ride i am looking for.
    The car is equipped with a moonroof - are there any known issues (both in terms of water and noise)?
    Here are some pics - what do you think?
    Any idea what those tiny pipes on the rear are?!
    THANKS GUYS!!
  16. #45
    BigCadMan_1's Avatar
    BigCadMan_1 is offline Cadillac Owners Fanatic
    Automobile(s): 93 Eldorado 4.9, 95 Fleetwood 5.7 LT1.
    Sep 2011
    Montreal, Canada
    445
    You will find what you need here:
    http://www.monroe.com/en-US/catalog/e-Catalog
    If you want to go the "passive suspension conversion" route, try these guys:
    http://www.strutmasters.com/SearchRe...llac+Fleetwood
    BTW real nice FWD Cadillac, keep us updated.
  17. Remove Advertisements
